dgeist57
- Dec 27, 2015
- 0
- Ford
I replaced the camshaft, lifters, push rods and the heads worked. After reassembly I have no spark. There's no power from the PCM to the distributor. I have no power to the start, run or coil feeds to distributor. I do however have power at the coil. I do have the 4.5 volts to the pip circuit. Oh I forgot to mention that I replace the timing chain and gears. Does anyone have any suggestions as to what may have caused this problem. I'm more than certain that the motor is not 180 degrees out. But I asked if it were would that be the reason I have no spark. I have checked the EEC circuit and it is fine. I also replaced the ECM with no luck
