jhammel85
Guest
Ah no kidding. Yep, my parents live on 295 and i take it on my way to 495.i work in pa.
Sooner or later you'll see that bumper pushed up. Lol
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I believe its good up to about 1/4 or 3/16. If im doing anything larger im doing 7018s. I try to stay away from 6011 unless its all i have left.I noticed the same thing with the 7014 recently. My girlfriends father has a ton of it and the hardware store was closed so I borrowed some. It looks great but a ton of slag. I worry about penetration though because on the boxes in the store it says it doesn't penetrate as deep.
I think with good beveled edges you could make anything hold with multiple passes.Oh ok so I should be plenty good with 1/4 if I bevel the edges?
Not a problem at all, the more info out there to help people the better I see it.Lol that's good to know! I'm gonna build a upper track arm bracket tomorrow. I'll be using 7014's for 1/4" plate.
Sorry for thread jacking but I was curious.
What your looking to do is called "Fish Plating". It works really well and will make your steering feel tighter. Ill prob end up having to do this soon. We have to do it a lot on 70s full size fords as we rip the frames in half where the box mounts. Check out the "La Bronc" build in my sig. Thats our mud truck we have built. Keep tuned in, this winter its gonna get funNo I have a plan. I had the ruff stuff upper bracket but I failed to plate my frame and ripped it off last time I went out. I'm gonna plate the frame with 1/4" then bolt it on this time. I'm gonna use home made large washers to disperse the pressure on the inside also. 6 1/2"x 1.25" grade 8 bolts and I'll be making it wide enough that it won't break in half this time. I'll post a couple pics here tomorrow when I'm done.
