1989 Ranger extended cab headliner
obs_Landon
4
gonzales, La
2.9 cologne V6
leveled with no parts
225/70r15
I need help with what years the headliners were the same, my headliner got all wet and cant be repaired, trying to find a new headliner, anyone know other ranger years with the headliner as a 89?
Thanks in advance
obs_Landon
4
gonzales, La
2.9 cologne V6
225/70r15
fastpakr
2,857
Roanoke, VA
I believe any Ranger with the same cab configuration (regular vs extended cab) in your generation (89-92) will work, and you may be able to go out further on years than that.
obs_Landon
4
gonzales, La
2.9 cologne V6
225/70r15
I dont think the next body style works but im not sure, pull apart only has 1 ranger the same body style in mine in the state so thats why im asking
fastpakr
2,857
Roanoke, VA
Hmm... I'd sit on the thread for a while. There are definitely guys here with plenty of older Rangers that could stare at them with a tape measure to compare to what you've got.
RustyShackleford94
Just some guy
355
IN
I would assume all the headliners for first and second gen rangers could all be the same or close enough. Just find one in a junkyard that has good cardboard and recover it.
dvdswan
2,910
Seattle, WA
Ranger XLT 2WD
RustyShackleford94
Just some guy
355
IN
If the new cardboard does have some crappy spots you can always cut them out and squirt foam it then sand it down smooth. Once you get the fabric on no ones gonna know
