PowerRanger
- Jan 4, 2017
- Reaction score
- 0
- Make / Model
- Ford
- Manual
Update:
TFI is getting power and ground. So next I moved onto testing the wire that sends signal to the ignition coil, according to the site I'm reading from, my test light should blink on and off when I crank the engine, however when I attach the test light, the light stays on. And when I have someone crank the engine, it turns off and does not flash at all. What's going on?? I double checked to make sure I'm testing the correct wire (second from the bottom of the harness) and I believe I'm doing it correctly. Any one have any input? This is a brand new TFI module btw.
Sent from my SM-N900V using Tapatalk
