- Jun 2, 2012
- 8,372
- canada
- Ford
After you unplug the 2 wire connector use a volt meter or test light on the 2 wires, key on engine off
Should be 0 volts
If you see volts then either ground wire is shorted or computer is grounding the control wire, unplug 60-wire connector on computer, then re-test, to find out which one is the issue
Should be 0 volts
