1985 2.8 no spark
85rngr4x4
13
Ohio
I have a 1985 ford ranger 2.8 cologne v6. No spark. The tfi was just replaced( I don’t believe the old one was even bad), the coil works fine and I just replaced the cap and rotor. I know that there’s a constant 12v going into the distributor but nothing comes out from any of the plug wires. Yes have been considering a Durasprk swap but I currently cannot. Any ideas?
franklin2
1,769
Virginia
Bronco II
Do you have a testlight? If you do, go to the coil and check for 12v on the red/lightgreen wire when you turn the key to run. If that is good, clip the alligator clip to a good ground and then probe the darkgreen/yellow wire on the other side of the coil plug. While holding the probe on this wire, get someone to crank it over. Is the testlight blinking?
85rngr4x4
13
Ohio
No it just dims, there’s no distinct flash.
85rngr4x4
13
Ohio
Also the cam position sensor wouldn’t have anything to do with it not grounding, right?
franklin2
1,769
Virginia
Bronco II
No cam sensor on this engine, it has a carb on it.
franklin2
1,769
Virginia
Bronco II
Pull the coil wiring plug off. Is it in good shape? Mine fell apart on me and I had to get another one. Check all the wiring plugs over there on the driver's side inner fender. Both my ranger and my Bronco II had problems with the driver's side tire throwing road dirt and water up on all that wiring when you made a left turn. I ended up putting a rubber shield in that area to stop it.
Unplug and plug everything in over there and see if you have any bad corrosion over there.
AndyB.
142
Cincinnati, OH
It could be the stator inside the distributor, it looks like this. You’ll need to pull the distributor, dive out the roll pin holding on the distributor gear, and use a gear puller to remove the distributor drive gear to replace it.
85rngr4x4
13
Ohio
Thanks, I’ll pull the distributor out tomorrow and check it for any damage or issues.
85rngr4x4
13
Ohio
Is there a way to check the stator once you have removed the distributor?
85rngr4x4
13
Ohio
