15 x 8 " wheels with 275/60's on Gen 1 Ranger?
Black P-38
Oregon Coast
'91
Rover 4.0 Aluminum V8 swap
I have been driving myself crazy researching an affordable wheel/tire combo for my Gen 1 2wd Ranger. I think I have decided on a set of 15 x 8" American Racing Outlaw 1 wheels, (5 on 4 1/2), with Toyo Proxes S/T's in a 275/60-15 size.
Anyone know if these will fit? The rims have a 3.75" back space, the tires are 28" diameter with an 11" overall width. I'm about to buy a wheel and tire to see if it will fit but hope someone has experience with a tire/wheel combo of similar size. The truck is not lowered but I may drop the rear a couple inches to level it out a bit.
I have the S/T's on my '94 Lightning in a 275/60-17 and love them, in fact, I'm about to buy my 3rd set.
Thanks for your help guys!
Mike
Original_Ranger84
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
Mike
I would say you might be able to but the tire might be sort of tall for a 2wd, but not completely sure because i have a 4x4 that had 30 inch tires with no lift. If they don't fit you could put a 1" coil Spacer up front and get it aligned so they don't wear, the back tires should be fine though.
Black P-38
Oregon Coast
'91
Wow, 30's with no lift... that's a pretty tall tire. My Gen I Lightning has 30" diameter tires and they still look big to me... for a stock suspension pavement cruiser.
I was fairly sure the 28" diameter would fit on the back but worried about the front.
I will probably run some taller/ stiffer springs up front with the V-8 swap so I'm hoping the tires will clear everything when turning. I like to keep the same size all around for good handling and tire rotations.
THANKS!
Mike
Original_Ranger84
20
2.8L, 3.0L
Yeah Thinking about it a 28"-29" tire is probably the biggest you would want to go with a 2wd. That would be a 235/75/r15.
