1350M vs 1354M
84bluebronco2
13
Central New York
If I'm not mistaken, the 1350 has 4 planetary gears vs the 1354's 6 gears. I know about the different front outputs as well.
Would a 1350M hold up behind a 4.0/M5OD that isn't used for any serious off road?
I'd rather have a manual T-Case, and I'm not striking much luck in finding a 1354M for sale....
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The first few years of 1354s had the 4-planet sets also.
No problem behind a 4.0L (it should survive behind a mildly-built V8 as well).
84bluebronco2
13
Central New York
I would like to have it so I can at most go play in a field, and maybe turn some 32's. I really don't want to build this truck to climb a wall lol. I'm gonna search around some more on TRS, but I'm thinking I might start looking for a 1350M... That would just leave sorting out my driveshaft...
85_Ranger4x4
17,848
SW Iowa
I don't thrash it very hard but my 1350M has done fine behind my 302...
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
I hope so because that's what I'm planning on..
84bluebronco2
13
Central New York
Thanks for the quick input guys! I've gotta see if it would be more cost effective to mock up a custom front shaft, or keep looking for that ever elusive 1354M...
A front shaft from a 90 to 93 should fit the bill. The 1350 case still came behind 2.9 and 2.3 engines on the 4x4s but they had the D-35. That will give you the shaft length you need.
Also, I know where to find a few 1354M's.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
The 1354 came about at the same time the D35 did, you won't find a factory D35 rig with a factory 1350 to my knowledge.
4.0B2
151
Walls, MS
4.0 v6
dustin used a single 1350 before doing the doubler and he didn't kill it. i wouldn't worry about it, use what you gotta use.
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
That. I looked at a '90 BroncoII in the salvage yard. It had a D35 and a 1354M.
Also, my 1350M is the only factory drive train piece left in my BII. It had 280,000 on it in 2005, when I put the V8 in. I'm swapping to a 1354M just cause I have it, and the front drive shaft already, and my 1350 finally was giving my issues this winter. it didn't want to engage 4hi right away. I'd say that's a pretty good run.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
:no2:
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Its working for me just fine.
I know RSH got hit t-case from a 91 2.3L truck.
The hybrid axle wasn't introduced until later. Even if the donor has a 28 the shaft will work. I know because I am running an Explorer front shaft with my D-28 axle and don't have any problems.
ltuck808
portland oregon
Adsm08, you said you know where a few 1354m cases are. Have prices on em?
ltuck808
portland oregon
Also did you find those door parts?
