1" body lift
The_Dealer
10
Macon, GA
Duh!
i was going to go with a 2" body lift, but i need to put to use some 1" PA blocks i bought for my ranger i never used. what size bolts do i need and how many? ive searched and searched but cant come up with anything
REDRUM
Central NJ
where did you buy the blocks?
how much were they?
are they 2" wide or 3" wide?
The_Dealer
10
Macon, GA
Duh!
3" wide, got them from 4wheelparts about 3 or 4 yrs ago for 1.25 each
Boggin
48
for a bronco II you should need 10 bolts, and around 6" long just to be sure. more than likely you could get away with 5", the bolts on my 3" body lift are 7". so if i were you id just get 12 (2 spares) 6" long bolts
xkotyx
20
Waynesboro, VA
the 3" kit for my ranger has 7" bolts. so id go with 5" and have alittle left over.
4.0B2
151
Walls, MS
4.0 v6
just whatever you do make sure you have plenty of threads on the them in case 6 inches is to long.. why don't you pull a stock bolt and measure? just add an inch.
Stxrangerbumper
Ontario, Canada
B2300 / f250HD
v6 3.0L/ 7.3L
hockey puck may-be hahaha just take her laughing
The_Dealer
10
Macon, GA
Duh!
might pull one, are they all the same length? i know they are 12mm
will i need some washers or nuts?
xkotyx
20
Waynesboro, VA
yeah you'll need washers and nuts.
4.0B2
151
Walls, MS
4.0 v6
i think they all are the same length except the ones at the radiator support.. i may do a 1 inch body lift in the future, i gotta fit 33's...
84bluebronco2
13
Central New York
Bolts are inexpensive. Purchase the 6" and apply hacksaw where and if necessary. Better to have 6 too long, in need of trimming, than 6 too short, with a second trip for hardware.
tjs4x4
ID
Does one have to BUY a body lift kit, or can u simply piece it together with parts? I'd like to see about a 2" body lift on my ex, along with my 2" suspension lift.
Nathan123
Millersburg Pennsylvania
2.9 Litre
I think I used 4 or 4 1//2" when I replaced my bushings (stock) so 5 inch should do, but I do remember needing 6" bolts for the very back ones so maybe 2 7" bolts for the very back.
