Introduction
This article discusses how to adapt the Chevy 2.8L TBI (Throttle Body Injection) to the Ford 2.8L V6. This swap is intended to be done on a 2.8L that has been converted to Duraspark.
The Chevy 2.8L Throttle Body Injection (TBI)
From 1986-1993 the Chevy S-10 2.8L V6 used a Throttle Body Injection (TBI) that replaced the carburetor used on the 1983-1985 engine. With this setup the 2.8L was now rated at 125 horsepower up from 115 horsepower. TBI, which is basically one step up from a carburetor, uses a pair of throttle body-mounted injectors to spray fuel into the intake manifold. The injectors deliver fuel into the air above the throttle plates. From there, the air-fuel mixture enters the intake manifold, where it is distributed to the engine’s individual cylinders.
The Conversion Process
Disclaimer:
The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Tools Needed:
  • Basic hand tools
  • Flaring tool
  • Wire Crimper
  • Grinder
  • Drill
  • Various wire connectors
Why Do This Conversion
Let’s start with addressing why you would want to do this as opposed to other TBI writeups on other sites:
1. The ford 3.8 injection will not work with a Duraspark distributor
2. The ford 3.8 injection pours too much fuel for a 2.8 which is 35% smaller displacement than the injection is designed for
3. The ford 3.8 injection requires you to jury-rig the IAC (idle air control valve) because there is no provision for it
We also figured a way to not need to change the fuel pump, and the fuel sending unit, which usually requires changing the tank because many carbureted Bronco II’s have the smaller sending unit opening which will not accept an in-tank pump. By doing so we have also avoided the need for even running new fuel lines, only a return line is needed.
This will not work with a TFI distributor because the signal generated by TFI distributors is a sine-wave AC current and the GM TBI needs a square-wave (dc) signal which the Duraspark distributor generates.
Parts Needed:
Parts from a GM 2.8 Equipped Vehicle: (example: 1992 S-10)
  • Complete engine wiring harness (one w/ manual transmission)
  • ECM
  • Throttle body
  • Air filter housing
  • TPS (throttle position sensor)
  • IAC (Idle air control valve sensor)
  • ECT (engine coolant temp sensor)
  • Knock Sensor (optional)
  • O2 (factory Ford 2.8 O2 will work)
  • GM 2.8 distributor module (from under cap)
  • EST (electronic spark timing) Module
  • Coil
  • Fuel Pump Relay
Parts from an ’80s F-150:
  • Electric fuel pump
Universal Parts:
  • Rubber fuel line
  • 2x universal relays
  • Distributor from a Duraspark 2.8
  • TBI to 2BBL adapter plate (and gaskets)
  • Fuel filler neck from ford explorer (for adding in return line)
  • Throttle cable linkage ball from carburetor (can be purchased from parts store, or taken from carburetor)
We went to the Junkyard and pulled the parts out from the donor vehicle
The Parts Pile
harness
Chevy TBI
ECM
ECM Pinout
We used the ECM PINOUT that has been preserved HERE.
To weed out the unneeded wires, and consolidate the harness:
removing wires
wiring
The wires needing to be spliced:
1. battery 12 +
2. switched 12v +
3. negative
4. fuel pump relay
5. O2 sensor
6. “crank” signal
Wire connectors not needing to be spliced:
1. ECT
2. IAC
3. TPS
4. EST module
5. fuel injectors
6. distributor module (7 pins total, we spliced ours anyway to clean up length)
7. MAP (manifold absolute pressure) sensor, which is usually mounted to the GM air cleaner if you want to use the gm air cleaner housing
8. knock sensor
Modifications & Adapters
You need to grind the back of the rivet off on the TBI linkage. Once you have ground the rivet off the post will come off and leave a hole for your ball “nub”
linkage
Cut off
throttle
accelerator
We then made the TBI adapter plate:
adapter
The spacing of the holes is slightly wider on the GM TBI
The modified Phenolic spacer:
Spacer
The gradual modification on the top spacer:
modification
With them loosely bolted together:
adapter and spacer bolted together
A cross-sectional view of how I used a die-grinder to modify the spacers. On the left is how the overlap was, on the right shows how I took material off; One side of each spacer to channel the air flow smoothly, the difference was less than 1/4″. Before criticisms fly, I deliberately left the finish rough with the die-grinder to promote atomization.
diagram
Mocked up on a loose engine:
mockup
left view
TBI and air cleaner
wiring
air cleaner
Distributor
Next is the distributor, the way it needs to be wired to the GM distributor module like this:
TBI wiring diagram
We did not use the TFI coil, we used the GM coil which was already wired in. If you wanted to use the TFI coil you could wire it the same way.
We wanted to utilize the GM Electronic Spark Timing control, in order to do that we needed to disable the mechanical advance inside the distributor, and to disconnect the vacuum advance. If you don’t do that the ECM would try to “double advance” the timing.
Using the GM EST made the most sense because there is not a proper port on the TBI that has venturi vacuum to properly actuate the vacuum advance on the distributor. Vacuum advance will not function properly on mere manifold vacuum.
Rico used safety wire, but a small tach-weld on the weights to immobilize them, anything will work, you don’t need to remove the distributor to do this if you don’t want to mess with your timing.
distributor
Fuel Pump
Next comes the fuel pump(s). What we did was use the factory Ford 2.8 mechanical fuel pump to draw the fuel from the tank, and feed the high-pressure pump, which we just put under the hood.
fuel pump
This is how the return line is run. (Ford Explorer filler neck which bolts in)
filler neck
Electronics
We spliced the O2 sensor into the wire on the harness.
The distributor module needs to be mounted to a heat sink in order to prevent premature failure.
Rico made this heat sink as over kill to prevent failure (which caused the demise of our first module)
heat sink
The GM air filter housing, with attached MAP sensor
MAP sensor
We mounted the EST module near the ECM under the dash.
Here are our (2) universal relays that we used, one is for the system power, the second is the fuel pump relay.
relays
The system power relay uses the switched ignition as a trigger, and the output goes to the ECM.
The fuel pump relay uses the green/white wire from the ECM as a trigger and the output powers the electric fuel pump.
The ECM uses a signal from the ignition switch to know when you are trying to start. We ran this wire (purple/white) to the post on the starter relay to get the “crank” signal.
The knock sensor needs to be threaded into the pipe thread fitting on the block (antifreeze drain), or on cylinder head If you choose to utilize the knock sensor. It will also retard timing in the event of pre-ignition, we chose not to use it.
I have been driving this for a couple months since we finished. The only problem was from not mounting the distributor module to a heat sink. No problems have been seen since we added a heat sink.
There is an “EST bypass” which when disconnected allows you to set timing that goes to the distributor module.
Contributors
This modification was performed and documented by TRS forum members ‘Cammeddrz’ and ‘RICO9’ and submitted to the author to publish at The Ranger Station to help other Ford Ranger owners.
Related Articles
2.8L Duraspark Conversion
Ford Ranger 2.8L V6 Engines
Last Updated:
About The Author
Jim Oaks is the founder of The Ranger Station, one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and cross-country routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road tests contributed by owners worldwide. His work has been referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information rather than theoretical advice.
Jim’s hands-on experience includes long-distance overland travel, trail use, drivetrain and axle upgrades, suspension tuning, and platform comparisons across multiple Ranger generations. The content published on The Ranger Station is grounded in first-hand experience and community-verified data, not marketing claims or generic specifications.
