Ford Ranger Mazda-Perkins Diesel
(Ford Ranger Mazda-Perkins Diesel)
(Turbo Diesel Shown)
The Ranger was introduced in mid-1982 for the 1983 model year and had an available 4-cylinder 59 hp 2.2 L Mazda/Perkins diesel. In 1985, a Mitsubishi-built 2.3 L turbodiesel with 86 hp replaced the Mazda diesel engine. The diesels were no longer an option after 1987. These Rangers are rare now, but a few seem to be showing up now on ebay and other classifieds (2008) likely due to the high gas prices and need for better fuel economy.
NOTE: Also check out 1983-1987 Ford Ranger Diesel Options
Engine Identification
Vin Code
(8th digit in VIN)
Engine Size Cylinders Manufacturer
P 2.2 4 Toyo Kogo
E 2.3 4 Mitsubishi
General Engine Specifications
Year Engine Horsepower & Torque Bore x Stroke (in.) Compression Ratio Oil PSI (@ 2000 rpm)
1983 2.2 59 @ 4000 / 90 @ 2500 3.50 x 3.50 22:1 51(3)
1984 2.2 59 @ 4000 / 90 @ 2500 3.50 x 3.50 22:1 51(3)
1985 2.3 86 @ 4200 / 134 @ 2000 3.59 x 3.54 21:1 11.4(4)
1986 2.3 86 @ 4200 / 134 @ 2000 3.59 x 3.54 21:1 11.4(4)
1987 2.3 86 @ 4200 / 134 @ 2000 3.59 x 3.54 21:1 11.4(4)
Notes:
(3) @ 3600 rpm
(4) @ idle
Tune-Up Specifications
Year Engine (warm) Valve Clearance Intake (in.) (warm) Valve Clearance Exhaust (in.) Timing ATDC Injection Nozzle Pressure (psi) Idle Speed (rpm) Cranking Compression Pressure (psi)
1983 2.2 0.012 0.012 2 1957 700 427(2)
1984 2.2 0.012 0.012 2 1957 700 427(2)
1985 2.2 0.010 0.010 (1) 1707 (1) 384(3)
1986 2.2 0.010 0.010 (1) 1707 (1) 384(3)
1987 2.2 0.010 0.010 (1) 1707 (1) 384(3)
Notes:
(1) See Underhood Sticker
(2) At 200 rpm
(3) At 250 rpm
Capacities
Year Engine Manual Transmission (pts) Auto Transmission (qts) Transfer Case (pts) Front Axle (pts) Rear Axle (pts) Fuel (gal) Cooling WO/AC (qts) Cooling W/AC (qts)
1983 2.2 3(1) 8(2) 2 2 5 15 10 10.7
1984 2.2 3(1) 8(2) 2 2 5 15 10 10.7
1985 2.3 3(1) 8(2) 2 2 5 15 13 13
1986 2.3 3(1) 8(2) 2 2 5 15 13 13
1987 2.3 3(1) 8(2) 2 2 5 15 13 13
Notes:
(1) 5-Speed Overdrive Transmission: 3.6 pints
(2) C-5 Transmission (2wd): 7.5 quarts
1986 Ford Ranger Mitsubishi Diesel
(1986 Ford Ranger Mitsubishi Diesel)
Ford Ranger diesel
1986 turbo-diesel 4-cylinder engine in a 1986 Ford Ranger   1986 turbo-diesel 4-cylinder engine in a 1986 Ford Ranger
Photos of a 1986 turbo-diesel 4-cylinder engine in a 1986 Ford Ranger
Ford Ranger Diesel
About The Author
