2.3L ('83-'97) Spark knock after ICM change, No CEL , runs much better except for knock when lugging.
Dredwolf
10+ Year Member
Broke, had to learn...
I have not posted in a long time, life does that, but I am hoping to narrow this down, parts are expensive these days.
1993 Ranger XL, 2.3 with dual plugs, and well over 300K miles, and right now, my daily driver when it was supposed to be my little farm truck.
CEL for a long time, other things took focus. Started running really bad last week, finally got a quiet day to diagnose.
Got the exhaust side coil pack error from the CEL, did some more tests, ordered a ICM I could afford with decent reviews.
Took time to clean mounting plate, used thermal pad material for heat transfer from ICM to base plate, and think I have a solid ground, but I can run a separate ground wire.
After installing the new ICM, CEL cleared immediately, and the little truck has noticeably more power, to the point of not needing to down shift during an aggressive test drive. It ran well during a 10 mile interstate and back roads test loop, to the point it was grin-inducing. 😁
Drove it today to take garbage, get animal feed, etc., and while it still runs a lot better, normal "I'm in my truck running an errand driving" is producing a slight spark knock with any slight lugging. I realized after looking at my notebook in the garage its been WAY too long since plugs and wires.
I did swap the coil packs around while trying to sort out the initial CEL., but I'm trying to avoid getting into a parts swap loop, I just can't afford it right now. Again, no CEL at all at this time.
Plugs and wires is an easy task. I had a slight knock last month, before the ICM change, but a cheap can of octane boost cleared the knock and I thought it might have been poor/cheap fuel.
Thoughts, opinions and snarky comments welcomed.
The dumbest thing I would check (I like doing dumb things first, or at least looking at them, never know... I know I don't do anything wrong but there's gremlins mixing stuff up behind my back, I swear...) is to be sure the plug wires are on correctly on both coil packs... I don't have which side is what memorized but you can mix up 1&4 or 2&3 but don't mix up the other combos... being batch fire the outers are combined and the middles are combined.
Other than that the only things that would cause it to have spark knock would be running lean which could be from a dirty MAF (electronic parts cleaner or MAF cleaner is all I'd use to clean them) or a bad O2 sensor that's just exceeded it's life span but that usually causes low voltage so would make it run rich so I would start with cleaning the MAF...
I assume by "ICM" you mean the TFI module on the side of the distributor. I'd check the timing before getting too involved in replacing parts.
No, he means the DIS module on the side of the intake, no distributor on a '93, crank reluctor wheel locked to the crankshaft so no timing adjustments at all...
So, I finally made time to work on the '93 tonight, outside, in the dark, because of....reasons. Anyway, prepping for the Great Sleet Storm of 2026 (not be to confused with the actual snow a week later), I decided to check the passenger side plugs while checking the antifreeze in the radiator....and had every plug wire on that passenger side come apart in my hands on the spark plug end. So.....fast forward to tonight, where I had a set of new wires, and Autolite Double Platinum plugs, and decided to fix the obvious failure. Dug around in the garage and found my Chilton and Hayes manuals, and per the diagrams, I had the plug wires correct coming off each coil for the driver side and passenger side. I went ahead tonight and did the passenger side, new plug wires and new plugs with the gap checked. I need to change the air filter, so I'll clean the MAF then. I don't think the O2 has ever been done, so that is worth a check too. Still no CEL, and quick run to the gas station seemed to run smoother, but the driver side plugs and wires still need to be done.
Okay, more progress. Pulled the throttle body tonight to clean it, but I need help replacing the hose off the valve cover to the throttle body, and the short piece under the throttle body that I think connects to a hard line that runs to the charcoal canister. The throttle body was VERY dirty, so I am pulling some oil through. I had three cans of MAF cleaner, and a half can of throttle body cleaner, the exact opposite of what I thought I had, so back to the store tomorrow.
Well, more progress, due to desperation, which is not always good. Last Thursday night, in an attempt to have my own vehicle to drive like a real grown-up, I got irritated and worked on the '93 2.3 util 2:00 AM out in the yard until I had it drivable. HF rechargeable lights are a blessing. I pulled the top half of the intake, changed the driver-side plugs and wires, and thought I had made progress. Upon inspecting the upper half of the intake, the ERG port in the intake was plugged solid. A set of HF scribes were sacrificed for the cause, and a extremely leaky can of carb cleaner, and the passage was at least open. The EGR valve was also full of junk, I cleaned what I could, could not find my Mityvac, but needed to go to work in 4 hours, so put it back together. A quick run up the main road, and the 2.3 was running a lot better. That Friday was a pretty day but started out cool. My work commute is pretty short, 25 minutes at most, and the Ranger was peppy, and pulling hills in 5th, same for trip home. The weekend was farm work, the Ranger just made a quick 20 minute garbage run, no issues. Today, Monday, the drive to work was also nice, but I needed to run to Columbia for work. My Ranger does not have A/C, but I have a rear sliding window, morning trip would not be bad...but meetings ran on...and on, and on. Did not get to leave for Columbia until 10:30 AM, trip down 26 was not bad, cool temps, the 2.3 was running well and pulling smooth, and because it could maintain speed 65-70mph, I realized I REALLY needed to replace or get the passenger front tire rebalanced. Work in Columbia when quick and smooth, completed faster than expected, started back up I-26 at 2:30PM, should be back in the office a little after 4:00 PM....not.
Before I got barely out of Columbia, I noticed the lack of power, and rolled up the windows, the spark knock was back with a vengeance at cruising speeds, and I was lucky to hold 60mph.....55mph......50mph.....45mph. If I kept the RPMs above 2K and used a lower gear, no spark knock, but that's not right either. I had to get off I-26....by this point, 45mph on a two-lane without an spark knock was impossible. The temp gauge seemed fine, and multiple stops to check did not seem like a full-overheat. Multiple stops and four hours later, I was home, but now I still need to sort out what is going on with my 2.3. When I changed the plugs (and I kept the old plugs) nothing looked lean, but it was dark.
After more reading tonight, I'm pulling the new spark plugs and re-gapping for certain to .044, and replacing the EGR valve, and cleaning the throttle body one more time, especially where the butterfly contacts the air passage. During one of the "rest stops" today, I bought spray Seafoam treatment to do that soon as I can.
I also question the temp gauge now, does a '93 2.3 have one or two temp sensors (like on in the block and one in a line)?
Unless the EGR valve is stuck open that won't cause large power loss, if the catalytic converter is melted into a wad that would make the most sense to me.
There's likely two coolant temp sensors, one in the block above the oil filter and one in the intake manifold near I think the #2 injector.
If it's hot under the hood but the temp reading right that would be the catalytic converter most likely...
I am going to change the EGR, it was still very dirty, and check the EGR tube from the header. The EGR tube insulation is almost gone.
Since I am on that side, I'll change the O2 sensor also, although the CEL turned off after I changed the module.
I'm driving it today, it's all I have at the moment, and this morning, in the mid-60's temperatures, it ran great, even for a short jaunt up the Interstate.
The radiator is three years old, but I'll run a flush, I did not flush it when I changed it in a hurry one morning.
Trying to eliminate everything that could cause a problem, I think trying to get more accurate engine temps may help. I'm trying to only spend on parts, but its temping to get gauges installed that actually give useable info.
It ran for years without a thermostat, but I got tired of being cold in the winter, and put in a 180, I think, in the winter of 2024.
I got a set of decent wires when I changed the plugs, and tried to not cross wires, but the OEM plug wire organizers are all broke.
I used to worry over those details on the Mustangs and CJ's, is crossfire even a thing anymore?
On the coolant temp, I stopped stressing about that stuff, these things all read low likely by the N in Normal like my '90 has forever... if the gauge stands straight up it's getting hot lol!
