How to Identify a Dana Spicer Axle: BOM Numbers, Model Tags, and Vehicle Applications
Identifying a Dana Spicer axle correctly is essential for repairs, upgrades, or replacement parts. Every Spicer axle carries a combination of Bill of Material (BOM) numbers, model numbers, and axle tags that tell you exactly what you have and what vehicle it came from. This guide explains where to find these identifiers, how to read them, and which resources to use for cross-referencing your Dana axles.
Where to Find Dana Spicer Axle Identification Numbers
How to identify a dana spicer axle
All Spicer Carrier Type axles are identified with a manufacturing date (1) and Bill of Material number (2) stamped on the right or left hand tube on driving axles. The Bill of Material number may also be found on the carrier in some models as shown in illustration (2A). For independent front suspension (IFS) axles, the B/M number may be located at one of three locations:
  1. A vertically positioned tag near the center of the right-hand side support arm
  2. Stamped into the left-hand side support arm (opposite end of the camber adjuster)
  3. Stamped into the “nose end” of the axle carrier
The location of the information will depend on the manufacturing date of the axle. The axle model number will be cast into one of the webs as shown (3), or it can be on the nose. Each axle also contains a gear ratio tag (4), and if equipped with a limited slip differential, it will have a tag specifying the type of limited slip lubricant to be used (5).
Refer to the appropriate model number section for parts identification and a breakdown of the Bill of Material. Please note that we no longer list BOM numbers here, as there are too many variations to include.
All Spicer Carrier Type axles are identified with a manufacturing date (1) and Bill of Material number (2) stamped on the right- or left-hand tube on driving axles. The Bill of Material number may also be found on the carrier in some models as shown in illustration (2A). For independent front suspension (IFS) axles, the B/M number may be located at one of three locations: 1). A vertically positioned tag near the center of the right-hand side support arm, 2) stamped into the left-hand side support arm (opposite end of the camber adjuster), or 3) stamped into the “nose end” of the axle carrier. The location of the information will depend on the manufacturing date of the axle.
Each axle contains a gear ratio tag (4), and if the axle is equipped with a limited slip differential, it will have a tag specifying the type of limited slip lubricant to be used (5).
Looking Up BOM (Bill of Material) Numbers
You can look them up in these documents:
1967-1978 Dana Axles – Look up BOM numbers under specific axles
1978-1998 Dana Axles – BOM numbers start on pdf page #9
Dana axle sticker
Looking at the axle sticker, we see on the top left Dana P/N 610659-1. If we go to 1978-1998 Dana Axles – BOM numbers, we see that this axle is from a Ford F250/350 SRW (Single Rear Wheel – Non-Dually) 4×4.
Dana Spicer axle sticker
The number on the top left of this sticker in 610366-8. Using the same method to look up this number, we find that it is a Dana 35 from a Ford Explorer.
Axle Tags & Door Stickers
You can also identify axles by their axle tags and the sticker in the door jamb of the vehicle it came from. Check out: Ford 7.5 & 8.8 Inch Axle Tag & Door Codes
Resources
Ford Ranger / Bronco II / Explorer BOM Numbers
Ford Dana 28 TTB BOM Numbers
Ford Dana 35 TTB BOM Numbers
Last Updated:
About The Author
