Introduction:
Do you find yourself working on projects, grabbing Grade 5 or Grade 8 bolts from the hardware store, but not knowing what to torque them to?
This should help.
Suggested Starting Values:
The below estimated torque calculations are only offered as a guide. Use of its content by anyone is the sole responsibility of that person and they assume all risk. Due to many variables that affect the torque-tension relationship like human error, surface texture, and lubrication the only way to determine the correct torque is through experimentation under actual joint and assembly conditions.
Grade 5 Bolts:
Bolt Size TPI (Threads Per Inch) Tightening Torque (ft lbs)
Galvanized Plain
14 20 11 8
516 18 22 17
38 16 39 31
716 14 62 49
12 13 94 75
916 12 136 109
58 11 188 150
34 10 333 266
78 9 537 429
1 8 805 644
118 7 992 794
114 7 1,400 1,120
138 6 1,836 1,469
112 6 2,438 1,950
134 5 2,857 2,286
2 412 4,297 3,438
214 412 6,284 5,027
212 4 8,594 6,875
234 4 11,651 9,321
3 4 15,391 12,313
* SAE J429 grade 5 bolts do not exceed 1-1/2″ diameter.
Grade 8 Bolts:
Plain Lubricated
14 20 12 6
516 18 25 12
38 16 44 22
716 14 70 35
12 13 107 53
916 12 154 77
58 11 212 106
34 10 376 188
78 9 606 303
1 8 909 454
118 7 1,287 644
114 7 1,875 938
138 6 2,382 1,191
112 6 3,161 1,581
134 5 4,988 2,494
2 412 7,500 3,750
214 412 10,969 5,484
212 4 15,000 7,500
234 4 17,794 8,897
3 4 23,507 11,753
314 4 30,286 15,143
312 4 38,266 19,133
334 4 47,545 23,773
4 4 58,100 29,085
* SAE J429 grade 8 bolts do not exceed 1-1/2″ diameter.
Notes:
Values calculated using industry accepted formula T = KDP where T = Torque, K = torque coefficient (dimensionless), D = nominal diameter (inches), P = bolt clamp load, lb.
K values: waxed (e.g. pressure wax as supplied on high strength nuts) = .10, hot dip galvanized = .25, and plain non-plated bolts (as received) = .20.
Torque has been converted into ft/lbs by dividing the result of the formula by 12
All calculations are for Coarse Thread Series (UNC).
Grade 2 calculations only cover fasteners 1⁄4“-3⁄4” in diameter up to 6″ long; for longer fasteners the torque is reduced significantly.
Clamp loads are based on 75% of the minimum proof loads for each grade and size.
Proof load, stress area, yield strength, and other data is based on IFI 7th Edition (2003) Technical Data N-68, SAE J429, ASTM A307, A325, A354, A449, and A490.
About The Author
Jim Oaks is the founder of The Ranger Station (TRS), one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and overlanding routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road adventures. TRS has been heavily referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information.
