wiring
madranger84
5+ Year Member
I have a 1984 carbureted 5.0 out of a lincoln town car in my 1984 ranger. I am using the stock wiring harness from a 1983 ranger but im not sure what which wires go to what so I can splice them to the wires on the motor. anyone have some kind of diagram. this is probably kind of confusing i don't really know how to word it so if you have questions please ask, thank you!
Have you looked in the Tech section? Lots of info there on the swap and many wiring diagrams available. What are you looking for specifically? Motor, starter, interior? It has it all.
Yes, Tech Section is here: http://www.therangerstation.com/tech_library/index.shtml
Look in electric diagrams
So you are not going to use the Fuel injection computer, right?
And you will be using a vacuum advance distributor not a TFI system which needs a computer, right?
Then there really are not many wiring changes outside of moving them out of the way.
Alternator wiring should be the same, assuming external voltage regulator and an alternator that uses an external voltage regulator on the '84 engine.
If you want to use a newer alternator then wiring changes are specific to the new alternator not the motor swap.
Alternators with external regulators are call 1G(1st generation)
2G have internal regulators as do 3G alternators
Google: 1G to 2G conversion
or 1G to 3G
There are only 3 other wires used on the engine.
Coolant temp sender, 1 wire
Oil Pressure sender, 1 wire.
Key on voltage to coil/ignition module, 1 wire
Tach wire, if needed, goes to coil "-"
If you have AC that adds 1 more wire, to compressor
Starter relay is not on the engine so its wiring shouldn't change
If you use an electrically heated choke for the carb then you will need to add that wire
ok i have most of the interior wiring installed already it it just for the motor accessories basically, thanks
ok i will need some help by looking at diagrams this is what i came up with but it still will not work, I have 3 wires coming from the back of the alternator, Battery, Field and Stator correct? I have the Field wire (orange with light blue stripe) hooked up to a wire that goes into the fire wall somewhere and then on my mutimeter it seems to be connected to the F on the regulator, then I have my Stator wire (white with black stripe) connected directly from the alternator post to the S on the regulator. and then my battery (black and orange) going though the firewall and back and connecting to the A on the regulator (i tested it and it is getting power through this wire) Im not sure where the wires go once they get through the firewall... is this correct?
