Wiring in my Dakota Digital Speedometer
Just wondering, I have not completed my diagnostic work, the limited amount I can do, but if the tranny is damaged internally from the accident it was in, will the 1995 5.0- OBD I A/T trans work as a quick change out? I have that complete truck, but opted for the 1999 Explorer when it became available because of all the parts I could use.
I think I have answered my own question. It appears that ‘98 thru’04 use a different EPC solenoid and the PCM reads it at a different frequency. Is it possible the ‘96 PCM does not recognize my ‘99 tranny?
It would set codes if the PCM didn't see correct parameters from controls or sensors in a transmission
What model is the 1995 transmission?
I am guessing its not 4R70W
AODE probably, so no, can't use it
You could use an older AOD, doesn't need computer but current PCM wouldn't like that
Yes, if vehicle was in motion when an accident occured then there could be damage to transmission,
I think at this time, based on all I have read, and about half of what I know I should double down on finding someone to reflash the ‘99 PCM to take out PATS. Then see if that PCM recognizes the tranny, if I can do that then I may know whether there is unseen internal damage to the D-OD parts of the trans.
In all this time I found one company and when I emailed the VIN# the tech guy said it would be 3-4 weeks and $300-$400 “probably” because he had to send it to another programmer.
I need to find one of “those guys.”
Check with local speed shops or if there's a place that can Dyno a vehicle, these places usually either do programming or know locals that do
