where is my drl module? 96 Ranger
bluebombersfan
I have no clue where it is, to be honest I'm not even sure what they look like, All I kno is that my daytime running lights are only working once in a while, and flicker with the high beams once in a while, problem goes away when I turn the night lights on, anyways, anyways, people are telling me that I should change it but just need to know where it is what it looks like exactly. I can't find it in my haynes book.:icon_confused:
behind the Drivers' side headlight (down low), I think.
What you are describing is probably a bad ground in the lighting system. When the lights come on, the DRL relay opens and turn off the DRL system. If you have bad wiring on the headlights, whenever the lights lose circuit, the DRLs will come on because the DRL relay closes. Look at the lighting circuit and grounds before changing the module.
