What's the trick to getting the tranny out?
Speedwagon
'87 2.3 4x4 5speed, trying to drop the trans. I have it all disconnected, and it's almost out... but I think I'm hitting the firewall, and it won't back out the rest of the way to drop out.
So what's the trick here?
Remove the y-pipe or drop the radius arm cross member.
Disconnect the exhaust hangers. That should let the motor rock back enough to clear the pinch weld. It has worked for me. I usually unbolt the exhaust to make things go smoother. I have the equipment needed to remove broken exhaust studs though.
Note to self: disconnect slave cylinder hose before trying to remove transmission.
Got it seperated now, though the snap I heard was my slave cylinder hose. Whoops. Guess I forgot that one!
