Whats broke on your ranger
Boggin
-Stole the idea from fullsizebronco
Currently my 94 is in need of a sending unit (getting a new one from fx2prerunner) and my hangers and shackles need replacing
my other ranger is just a bare frame and my other b2s have literally nothing,, but i think the window still rolls down? theyre only parts rigs. and the other other ranger needs a slave cylinder. What does your truck need?
Drivers side door handle, Passenger window motor, and my wiper fluid doesn't work. Probably just gonna wire in a new button instead of cracking open the steering column.
my gas gauge doesnt work either haha.
got a bad backlight in one of my sunpro gauges (so minor, but drives me insane!), have a niceee shake at idle, maybe a bit of a misfire when it's in the mood for it. VERY NICE oil leak at the remote oil filter manifold, washer pump dont work, drivers side window motor needs a little help on the way back up sometimes, and i guess thats it. not too bad for a $400 truck lmao.
oh and i need to pull a few dents and straighten a few body lines and panel gaps and re-paint it when i get the chance.
oh i almost forgot the WORST part, the stupid ass valvecovers leak oil conveniently on to the manifolds, and it makes for one hell of an "air freshener"/stop light smoke screen!
hmmm
maybe.....whats not broke on your ranger would be easier to answer for me:icon_surprised:
Driver's side door handle (on the inside) needs fixed. Also have a floppy driver side mirror. That's about it.
I guess I'm also waiting for my extended brake lines and Stone Crusher steering set up to get here. :)
Dead bulb behind fuel gauge, window motor is loose on the drivers side, and a loose nut behind the steering wheel ;)
missing door panel passenger side leaks oil passenger side valve cover gas getting in the oil so idk what the problem is there. the headlight are aimed all ****ed up and it needs a windshield. oh and the speedo cable squeaks when its cold outside.
Sadly mine is getting this way as well.....
i am pushing a million miles on my cab and frame...shits just wore the fawk out...
the doors have been pretend doors for 8 or so years:icon_rofl:
my a/c condenser leaks bad. and my horn brush is so worn out i have to turn the wheel back and forth if i want to use the horn.
other than that everything is tip top
