waynaferd
- Jun 28, 2010
- Automatic
I'm working with a bare-bones, manual steering, 5-speed, 2.3L reg cab short bed 2wd 96 ranger.
The donor is a running 92 F-150 2wd auto w/ around 120K miles. So far I plan on yanking the power steering box to have that luxury, and obviously the motor and trans.
Is there any other parts I could use, like front coils (cut to lower the front a tad)? I plan on hanging onto it for a little while, as I may find some good parts for my 94 4x f-150.
And lets fast forward with fingers crossed and all is well.....I only plan on swap headers, a cold air intake, and a noisy timing gear ( I figure the chain might be stretched, so best to be safe
), and maybe a shift kit for the tranny, and a tune-up and fluid change, of course. And aggresive sounding duals.....
What could I expect for rough MPG estimates, after say 2 mos of the newness (read: racing everything in sight and seeing how fast I can wear rear tires)?
How's the roll-on acceleration from 65-70 to faster? Right now there's some grades on the highway I lose about 15mph, and with a strong head wind I need to use 4th gear to keep up speed. Then the Hemi RAM A-holes that ride beside me or go too slow after passing because they know I can't do anything about it....would the stock 5.0 cure all that?
Actually, I had a 96 T-bird 4.6, and went good for its size/weight, and was wondering if anyone could give a power comparo. I know the Ranger will haul A with a 302, but I dunno about a stock high mileage 302.
Thanks for any insight, and so far the tech library has been awesome!!
And would this motor have the good intake and heads? I read there was some improvements thru the years....
