What is required to run 33s?
Featured Build Threads
CatBee
Forum Member
Marietta
GA - USA
Other
1993 Mazda Miata
Vehicle
Drive
4.0L
235/75R15
I have a '93, 4x4, single cab, and it has the stock tire option of 235/75R15 which are 29s. They of course fit fine, but I want to try and get some bigger ones the next time I need to get tires. I know 31s (265/75R15) were the biggest stock size for my year of truck, but I want to know what modifications have to be done to fit 33s, specifically a 33x10.5R15. Currently the only suspension modifications is a front lift/leveling kit. I did not install it so I don't know how tall it is, but it is close to the height of the rear, maybe an inch lower the rear is, and the rear appears to be unmodified. How big of a lift, suspension or body, is required to run 33s without worry of rubbing?
If you cut your fenders, then you don’t need any lift :icon_rofl:
3-4” of lift would probably work unless it never gets flexed up off-road.
Personally, suspension lifts are better than body lifts. You will want long arms for the front though, because flex and ride quality can be a thing.
The biggest question is what gear ratio do you have? 3.73 may be acceptable but not ideal. 4.10 is much better.
I have a 3.73, but right now the gearing is kind of short imo. I did the gear ratio calculator stuff for cruising and I'm ok with the rpm a 33 inch tire would give me, that V6 makes good low down. Is that 3 or 4 inch measured from ground to frame rail? Or some other point?
That depends. Of you do a body lift, the distance from ground to frame won't change. If you do a suspension lift (highly recommended), it will. Of course, when talking about tires, you're interested in clearance from tire to body. Unless you are highly skilled and experienced, you will most likely buy a lift kit from an established manufacturer like Skyjacker. It will include everything you need and you just install it. You don't really need to worry about the measurements from ground to frame. You install the parts and it does what it does. If you have a good flat, level surface to park on, it is good to take before and after measurements of all kinds of things so you can make comparisons and know exactly what changed and how much.
One thing people often don't think about is that tire clearance is a dynamic thing. It changes in many ways. The front is the hardest part. When you turn the wheels left or right, the tires get closer to the fenders because the effective diameter for fender clearance gets bigger. You must actually measure diagonally across the tire. So it is bigger than 33" diameter. If one front tire climbs up on a rock and bears most of the front weight of the truck, it geys stuffed up higher in the fender and making a turn at the same time is the perfect storm - diagonal tire pushed up high. That is ideally the scenario you want to measure and plan for. If all you ever do is drive slowly on flat level pavement, much bigger tires fit without lift.
That about sums it up.
Eric pretty much covered it.
I certainly agree with 3.73 gears and 31” tires being not exactly a suitable combination. My 92 with a 4.0 and 30” tires with 3.73 did pretty alright. My green 00 with the 4.0 and 4.10 did good with 31” tires, but when I changed to a 5.0 and 3.73 gears it wasn’t so happy on 31” tires, but that’s ok because as soon as I’m done dealing with a few things on it, I’ll be going to a 28/29” tire. The 31” tires rub a bit with it being lowered about 4” and smaller tires because of the drop were always the plan, I just needed it before everything was done and I didn’t have the rims and tires yet for the change.
My Choptop Bronco II did alright with 2.9, 4.10 and 33” tires, but it didn’t like the 35” tires so I went to a 4.0 and that’s a lot happier. I keep going back and forth on if I want a little more gear or not.
Lift kits are measured in inches of lift they probably. You need a 4” suspension kit (preferably, and preferably Skyjacker with the extended radius arms), or you need to add at least a 2-3” body lift to your current configuration. For clearance that’s your minimum. Or you could go bigger on the lift, like a 6” suspension. Or do a 4” suspension and a small body lift. Don’t buy a cheap lift kit, this is one of those “you get what you pay for” kind of deals with these rigs.
I'm pretty happy with my 5L explorer with 31's and 3.73's, it's not quite happy towing my boat (~3000 pounds) in overdrive at 60 but unloaded it's fine... my '90 Ranger with 31's and a 4 cylinder and 4.10's wasn't a great time, even my '97 with 29's and 4.10's isn't ideal... if you're on flat ground you'd probably be fine with 33's but 5th would be near useless if I had to guess...
The leveling kit is probably 1"-2". You get a lot more forgiveness with the 33x10.5R15 tires over the 33x12.5R15. Those recommending the suspension lift over the body lift are recommending for lots of good reasons, one of them being that it doesn't raise the center of gravity without improving the suspension geometry. It will perform better, be safer in general, and allow you to have better steering geometry depending on the kit you get.
If you are not afraid of spending money, companies like Autofab and Solo Motorsports provide cut and turn kits for the Dana 35. I'd give them a look and if you can afford it, I'd recommend those as they bolt right up to your stock mounting points. It is my understanding that 33" tires will fit without body modifications using these kits. You would need to cut the body panels to get 35" tires.
15x7 or 15x8 wheels with ≈4–4.5" backspacing is recommended, but no matter what, if you really want to make sure you get the right stuff the first time, Speedway Motors makes a backspacing tool that will measure this stuff for you with a bolt on kit. I recommend this if you are trying using some mix and match lift kits.
Below is a chart for cruising speed in 5th gear:
MPH = (RPM × Tire Diameter) / (Trans Ratio × Axle Ratio × 336)
Axle Ratio60 mph65 mph70 mphNotes
3.731,8001,9502,100Quite tall; may feel sluggish on hills or when passing. Many owners re-gear.
4.101,9802,1402,310Better balance for 33s — keeps the 4.0L in a stronger part of the powerband.
4.562,2002,3802,570Even stronger pull; common swap when running 33s or larger.
  • 4.10 gears + 33s → Most popular and recommended combo by owners running this tire size. Good compromise between highway manners and usable power.
  • 4.56 gears + 33s → Excellent if you tow, wheel, or want strong low-end pull. Slightly higher RPM on the highway but very capable.
Stock output for the 4.0l was approximately:
  • 160 hp @ ~4,200 RPM
  • 220 lb-ft torque @ ~2,500–3,000 RPM
Stock output for the 3.0l was approximately
  • 145 hp @ 4,800 RPM
  • 165–170 lb-ft torque @ ~3,000 RPM
Powerband characteristics:
EnginePeak HPPeak TorqueStrong PowerbandNotes
4.0L V6 (most common 4x4)160 hp @ 4,200 rpm220 lb-ft @ 2,500–3,000 rpm2,100 – 3,500 rpmBest match for bigger tires and towing
3.0L V6145 hp @ 4,800 rpm165–170 lb-ft @ ~3,000 rpm2,200 – 3,800 rpmSimilar character but less powerful overall
2.3L I4~100–115 hp rangeLower torque peakNarrower, lower RPMLeast common in 4x4; feels weaker with 33s
These engines have a broad, flat torque curve. They feel strong from just off idle through the mid-range but taper off if you keep them above ~4,000 RPM for long periods. Consider the powerband when you are deciding on your final drive because redoing them are a pain in the butt! The 4.56 will keep you in that powerband on the highway which will make it feel a lot more responsive in passing.
I hope all this helps you with your decision!
I am not sure if this will help the OP, but I was just barely able to run 10.5x31" tires on my 89 STX Ranger with stock aluminum wheels. It had a 1.5" factory lift with air bags in the rear to level it. It would just barely rub at full lock when turning. I took it in very rough off-road conditions and never had and issues at full articulation as long as I didn't turn at full lock. Even then it was not a serious rub and never hurt anything.
I run 10.5x33" on stock Alcoa aluminum wheels on my 02 FX4 Ranger. I have run it with MT and AT tires. I don't get any rubbing in rough off-road conditions. The only thing I did was a 1.5" T-bar lift in the front and air bags in the back to level it. I had to bend the mud flap bracket a little on the left side to get full clearance there. I did try 11.5x32" tires first and they would rub sometimes when articulating a lot. It was not an extreme rub but would get my attention.
Couldn't help but notice...
@Curious Hound
@IRKillroy
You fellas must be related...
Disregard wrong tire size. Im running 31's with no problem. Stock 93 XLT
Even if we're not, this gentleman has an incredibly good sense of style.
It wasn't intentional by any means, but yes it is a wonderful style.
Event Coverage
Featured Ranger Based Vehicle
