- Aug 6, 2007
- Sacramento, CA
- 2.3 (4 Cylinder)
- Manual
Filled it up with gas and calculated the gas mileage. 27.1 mpg, all freeway driving.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
looking at your plate frame...Put a hitch receiver under the back. It's very hard to do with one shoulder unable to support weight. Had to use my knees and right hand to try and hold it in place while the dead left side just threaded the nuts on. I had jack stands on 4x4s holding the bumper in place.
I even found the instructions for the factory jack hidden in the jack cover
... Planetlooking at your plate frame...
Save the what?
Save the Rangers!looking at your plate frame...
Save the what?
AJ
How many miles on the F-150 when you replaced the water pump?Have you ever replaced the water pump?
My '92 f150 always had Luke warm at best coming from the heater. I rebuild the cooling system, replaced everything, radiator, hoses, water pump, ect, except the heater core. The heat was blasting that next winter, I think thr water pump was worn and didn't have much flow.
Save the what?
AJ
Most diff covers are fairly heavy. You should be able to sand off the rust, paint, and reuse.I crawled underneath it to assess the task of changing the differential oil. I need to take a better look at when it isn't raining because the cover appears to have some pretty good rust on it and I need to determine if it is something I can clean off and paint, or if I need to get a new cover. No rust on anything else. This is California. Rust doesn't appear on anything other than brake rotors...............and, apparently, Ford's differential covers.
