sgtsandman
Automotive Technician
TRS 25th Anniversary
Ham Radio Operator
GMRS Radio License
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
I attempted to fix the 2019 in a parking lot with no success. The low oil pressure alert popped up. So I loaded up the tools in the 2011, stopped at a parts store for an oil pressure switch, and changed the switch. The warning popped right up when I cleared the code and the code came right back. It was P0034 on the Scangauge II, which doesn't make any sense since the Shop Manual says that is Turbocharge/Supercharger Bypass Valve A Control Circuit Low.
So, I followed the girlfriend home in case there was an issue and had her stay off the highways since it could go into Limp Mode (which it did). So, the truck is home in the driveway, where I have more tools and equipment to work on the issue.
I'll hook up the computer with Forscan and see what that tells me tomorrow. Doing some searching on the web, an oil change might help (It needs one anyway), and fuse F12 in the Battery junction Box may be an issue. One needs done anyway and the other one might be free, if it is a fuse I already have in stock. I'll do one at a time and see what fixes the issue. After seeing what Forscan has to say on the matter first.
