2.0L ('83-'88) Vacuum lines
DJonezy13
Firefighter
EMT / Paramedic
Iowa, USA
I've had this truck since I was 16 and finally decided to completely rebuild the engine. I pulled the engine over a year ago and took pictures of where the lines go on the carb. But, have since then lost that phone in the river. Engine is back in and running but poorly and I feel that I've got some lines in the wrong places. The diagram on the front support is still there but reads like Greek when it comes to which port on the carb the line goes to. Does anyone have a picture of the carb with all lines attached correctly? The tech library has the diagram for the 2.3. Mine is a '87 with the 2.0L and 5 speed transmission. I already removed and capped the EGR and smog pump lines
Do you want to hook all that back up? I would plug everything and go from there. Hook the PCV valve and the power brake booster up if you have one and see what happens. If it runs better then you can experiment with hooking up the distributor.
