Rage4order
Urgent brake help with additional question
Just put a set of new rotors on 96 Ranger last Sunday. Driving home today I noticed limited stopping power, wth the pedal going to the floor slowly. Stopped and looked underneath and I could see a drip in the parking stall.
Looking under neath the front end, towards the driver side, I seen some fluid driping off the frame just between the coil spring and fame. Checked the line to the fbrake and it was bone dry. Checked the resivoir and it looked full.
Drove it up and down the driveway and the pressure seemed to build back up with stopping power.
Anyone have any ideas ??
Just need to know if Im safe to drive
Looks like I need new lines. Do I attempt it myself or let the Pros do it?
If I do it myself, I need to know the specification of what size of tubing and fittings I would need. and if it is worth Noob to do it
The truck is a 96 2WD Ranger with rear ABS. Plan on changing the front lines only. To the best of my knowledge, the lines have never been done before, so I would assume that they are the original lines.
Line size ??
Fittings ??
I know that I need a Flaring tool as well, would I need the bender as well?
Thanks in advance
Line size ??
Fittings ??
Thanks in advance
