U-Joint Fit inside axle, good or bad???
So I am just going to peen the yokes, then I will put 4 tack welds on each cap and use what I have. I don't have the money to get new ones at this point. Maybe in a few months I can get the $$ to get some better shafts and get them ready for my next failure...but I have to get this rig back on the road so I can have some fun before winter....and fun during winter!
Everyone OK with this fix?
mine egged out the first time i used 4wd after installing the 760x's and full-clips... almost all of the yokes are big enough to move the caps with my fingers.. i even broke the center slip yoke ears (was stuck, and reversing, cut the wheel a bit, my bad)...
so i should probably do the same thing as was described for Blur2u, huh?
BTW, I had a cap spit the clip and walk out of a FACTORY OE shaft & joint once. Its MORE than possible for them to spin and spit clips on perfectly good shafts under the stress that lockers put on them.
Ditto.
Upcoming TRS Events
Featured Ranger Based Vehicle
