Tseter
- May 10, 2013
Greetings and warning this may be a huge post but i will try to explain what has happened in detail .
I got a truck from a guy in Grand Junction with a trailer the year before last for $1000. the truck was out in the mid east back in the Mag chloride days and its a rusty bucket. It is a 2WD fuel injected 4 banger with a 5 speed manual transmission.
I just got myself a job delivering newspapers and during last nights (this morning) devilry my truck starting to miss really bad. It lost a lot of power and starting to ping or knock not 100% sure. At first I was fearful that it blew. But the more I drove it was just feeling like I lost a cylinder. and smelled an extra gas from the exhaust. I got it home parked it and then later today I drove it over to a nearby mechanic and he said it was missing. And suggested to check the plugs.
Soo off i go to autozone and picked up new plugs and plug wires to replace the plantum 2's that were in there i picked up the motor-craft and gaped them and then fought to replace the driver side plugs. I finished that and started up the truck still no good. still bad idle. So i think thought maybe i'll go to auto zone and see if i was lucky enough to have then code read it.
I slammed shut the hood so it would latch and then tried to start up the truck and it began to run so bad it would not even idle proper and if i gave it gas it would simple die.
I have replaced the following since i get this truck; Plugs wires, Spark plugs, Brake Master Cylinder, and Passenger brake line. What would be causing this and what is the best way to fix it. I will note that I do not have a lot of tools to check things due to former roommate and family member's sticky fingers and pawning to get money for drugs. Nor do I have a lot of money to get replacements.
As stated in my introductions I live in the Denver Colorado area and If you are able to come over and help this weekend and get it running once more I'll do my best to repay you back as best I can. Or if you have a vehicle sitting around that is legal that I can use to deliver the papers for my job.
thanks in advanced
Tseter
thanks in advanced
Tseter
