I grew a set of big cahona's today and drilled 15 holes in my roof to mount a set of cab lights.
I found them in a local junk yard and got them and the factory wiring harness for $15.
I had a tough time deciding how I was going to get to the center of the truck without standing on the cowl. I rigged up a little walk board between 2 work benches (yes the ladder is designed to work like this as well).
Cab lights mocked in position. I used the masking tape to mark the roof and to keep from chipping the paint when I drilled. I got lucky that my brothers '89 F-350 with factory cab lights was parked next to mine in the garage so I could use his a measuring truck.
I decided it was better to create my own wiring harness because drilling the roof to a size large enough to fit the factory wiring end through was something I didn't want to do; not to mention that snaking the wiring harness through the roof.
Here is a finished product. Looks a ton better with the cab lights.
I also got some more parts for my electric fuel conversion. Now just waiting on my pump and filters to get here. Both should be delivered on Thursday. I plan on doing the install next week.
