Tow Pig / Daily Driver Build
I snapped a few pictures today out in the field while I was picking up some stuff.
I also had to replace the engine cover bracket.
The broke one.
The new one.
Cover re-installed.
I also got the Ranger HVAC shut off so the antifreeze will not be flowing through the heater core when the HVAC panel is in the Max A/C position.
A few random shots of the engine bay.
The E4OD was replaced by the 4R100 when the first Super Duty pickups came out. The 5R110 transmission (torqshift) came out in 03 with the 6.0L diesel.
That's what I thought, but a family friend had his rebuilt (1998) and it was the 4R100, not the E4OD...Wonder if it was transplanted before he bought it :icon_confused:
SVT
I got another part for my intercooler install.
Now I am waiting on my intercooler pipes to get here. I am having a custom set made specifically for the OBS with a Super Duty 7.3 intercooler for $200 shipped. They are one piece units. The only connections is at the intercooler and the spyder.
Lookin good there...Cant wait to see the pipes :icon_thumby:
SVT
SVT
Me either. I have seen pictures of them online and from what the guy building them has sent me and they look good.
Is that a stock spyder from 99+ Superduties?? Where did you find that one, it'd be nice to find those parts for my dad's 97 F-350...What are the mods needed for the core support to fit the IC?? Take plenty of pics on that one, as I know John (railman) would like to do that to his as well...
SVT
SVT
It is a factory '99-'99.5 Super Duty spyder. The '99.5+ 7.3 had 3" plenum intakes where the '94.5-'99.5 had 2" intake plenums.
Here is a good write up on the install.
http://members.localnet.com/~boys3/
The install doesn't seem to be all that bad. Just 2 holes to cut for the pipes to come through, 4 small brackets to make, and a few factory braces to modify a bit.
I have been looking for the silver XLT dash and door trim for a while. I happened on a set of the dash trim on eBay. The parts happen to be in Evansville, IN so shipping was exactly 1 day.
Before:
After:
I also got my TS Chip switch mounted. It is out of the way and not very noticeable.
I didn't like the way the mirrors were looking and didn't want to buy a new set. I decided to try some Mothers Back to Black polish. It is supposed to bring the black back to vehicle trim. Needless to say, it worked.
Before:
After:
wow, i'm gonna have to try some of that mothers. truck's lookin good
It took a couple times of application over and over, but in about 5 minutes the whole mirror looked like that.
That is a really good looking truck man!! I have always wanted a diesel Ford since I drove my dad's powerstroke.
I decided it was time for a boost gauge and a triple pillar pod instead of the dual pod.
I ran the tubing to the intake Y-pipe so I would have a more accurate boost read out. The directions say to put it in the MAP sensor boost line that comes off the passenger side intake manifold.
Now I know what kind of boost I am making. The most boost I saw driving today was 25 PSI. The boost gauge would jump around once I got above 18 PSI.
Nice...But your pyro looks a little high from here....lol
SVT
SVT
Lol. That is what it does when I shut the truck off. It goes to different spots each time the truck is shut off.
I got the CCV (Crank Case Ventilation) mod done. The o-rings on my CCV was blowing through the seal between the valve cover and the vent case. I figured it was a good time to do the CCV mod while I had the vent off so I could turn it around to make it easier to run the tube.
I also decided to cut the vent tube out of the factory air tube so I could use the factory mount for it.
I capped the factory CCV inlet with a 3/4" hose cap. It fit on there really tight, however I want ahead and put a clamp on it for extra measure
For reference, the part numbers for the o-rings for the CCV is as follows:
Bolt O-Rings:
F4TZ-6769-A (2 o-rings needed, 1 per part number)
CCV to Valve Cover O-Rings:
F4TZ-6769-C (2 o-rings needed, 2 per part number)
Parts List for CCV mod:
1. 2x - F4TZ-6769-A
2. 1x - F4TZ-6769-C
3. 1x - 3/4" 90* Heater Hose plastic elbow
4. 3x - 7/8" to 1 1/4" hose clamps
5. 12' +/- 3/4" heater hose
Cost to do CCV mod this way was roughly $45.
I got my Garrett 1.0 turbo housing today.
I am going to put it on while I have the turbo off when I am installing my electric fuel conversion.
I have the 2 filters (water/fuel separator, and 2 micro fuel filter), 2 filter bases, regulator, oil pressure switch, fittings, and banjo block coming.
