94_Xploder
- Dec 27, 2012
- Automatic
I have a 94 explorer 4x4 and im going to be lifting it here pretty soon. Im not new to the 4x4 world as i've had a couple RBV's before and some toyotas. What im wanting to do is keep the COG down, in my 92 ranger I had with a 6in skyjacker class 2 on 35's the truck felt really top heavy same in my tacoma that was SAS'd on 37's and I know that with the explorer it has even more weight to the cab so I could see it being worse. What im thinking of doing is getting a set of jeep coils that would lift a RBV around 4in's and then building a set of coil buckets that are 2in's taller then the factory ones and something like the f-250 shock mounts and a set of extended radius arms that way I will have around 2in's of lift and have more droop then one would with a leveling coil spring. Of course id run a long enough shock to take advantage of the travel. Has anyone here heard of someone doing something like this? I'll most likely run a 33x10.5 or a 34x10.50 with locked axles front and rear. I believe that this would be a pretty capable set-up, Any opinions?
