Thermostat housing options
socal_Redranger
Forum Member
Riverside
CA - USA
Drive
2"
33s
I have 09 ranger sport that I am looking for an aluminum housing for it looks like this
Having only one plug in it and I keep finding housing with 2 plugs
or bare housing like this
I fought this housing from dorman/duralast one
Has anyone else encountered this problem and which one did you go with?
Your plastic housing looks like it has the space for that second sensor. I don't see why you couldn't use the first and just leave that sensor unplugged. If having it sticking out bothers you, it might be a pipe thread. If so you could buy a plug at any hardware store.
Edit: I just realized those are held in with clips. No pipe thread there...
I installed a new alum thermo hsg back in Dec 2025 to replace the leaking OEM plastic. I only had one temp sensor connector... IIRC. I ordered mine from Simmons Auto. It was more expensive than any others. But was recommended over the others by most of the folks on this forum.
Unfortunately looks to be out of stock at the moment.
