The Road Ranger. 1997 SEMI
Step Trailer Update:
The Road Ranger and step trailer are motoring down the road great. But I noticed the framework for the trailer “pin” is scraping the truck bed, on the inside corners where the “fifth wheel“ assembly is, when I’m making turns. When I first built the trailer, that fabrication was hitting the back fenders on a sharp turn, and I had redone it all before I went up for nationals this year. I measured it 1000 times, and before I finally welded it, I went in the church parking lot across the street and drove it every which away and in circles and turns. Everything cleared. But I can see the scuff marks, and of course that scares me, I don’t want to bind it and break something.
I haven’t gotten much done with all the hurricane Rugrat refugees in the house, but I took a couple of them across the street, and I did everything to that truck I could think of, measuring everything, and I think I figured it out.
I don’t have the classic pin in the plate fifth wheel. It’s an upside down ball trailer hitch, so the trailer can tilt side side. I knew that, and I thought I had still left plenty of clearance for anything that would happen on the road. And it looks like I was right.
First, the bed of the truck tilts up a little bit towards the back. That was by design a little bit, so when I have a load, it will level out. The only place it’s scraping is on that last 2 inches, on top of the light assemblies. That’s 1/8 inch aluminum on top of some fairly thin 2 x 2 tubing. The pin pivot point isn’t centered between the two axles, it’s actually just a few inches in front of the back axle, which was also by design, so the truck would “pull” that axle and the trailer, not “carry” either one.
Since the city widened the road and put in a slightly elevated sidewalk at the end of my driveway (that’s now a steeper incline), there’s a pretty pronounced hump. That sidewalk/hump is right under the rear wheels when I turn left or right out of the driveway.
Apparently, when I pull out and I’m turning, the truck will tilt as much as 6-7 inches from one side to the other, which doesn’t happen on the road. At the same time, the back wheels of the trailer are still sitting square on the driveway. That one location/turn is apparently where I’m getting interference.
There’s only a scrape on top of the light assembly on the left. When I turn left, I have to cross the lane on my side of the road, so it doesn’t tilt as much as if I turn right. On the right, the pin assembly has actually caught on the inside corner of that part of the bed, and actually bent the 2x2 tubing, crushed it, about a half inch. I figured out that happens because it’s a much tighter turn to the right creating a bigger slant on that hump..
The frame and fenders are all attached solid to the truck frame, it’s only the axle that floats underneath it. When I did my twist and turn test across the street, I also realized that in tight turns that rear axle will move left or right about an inch to either side. No big deal because it tracks going down the road, but that has the effect of moving the pinpoint to the left or right, which affects the clearances in a tight turn.
With all that, I would have to make some pretty substantial changes to the 2 x 2 frame I installed on top of the truck frame in the back. The other solution was just to use a longer offset hitch for my pin, which just raises the assembly up a couple inches. That’s easy to try and remove if it doesn’t work. So, that’s what I did, I swapped out the 4 inch offset for a 6 inch offset.
One of the other reasons I redid that whole pin assembly before nationals, was because the trailer was not square left to right with the back of the truck (just top step deck). It also slopes up a little bit towards the front with that same idea that when there was a load on it, it would all level out. I haven’t seen it on level ground since I swapped the hitch, but I’m concerned it might slope up too much now.
I can fix that by correcting another oversight. On the rear of the trailer when I put my axle mounts on the frame, I put all three the same on each side. With the double axle and the equalizer, the one in the center should actually be longer so it hangs lower. Now, the springs can hit the bottom of the frame when I go over a speed bump or something like that, they’re not totally free on that equalizer at its limits.
So my plan is the next time I hook it up, which will be Saturday, I’ll measure it all out again, and then replace those middle spring/equalizer mounts with longer ones that will level the trailer front to back where I want it. That will bring the tail end up a couple inches, but I can live with that.
I now have all my brake parts to do the brakes on those two back axles, so I’ll just do it at the same time, but not right now.
Two points in presenting all this.
First, I would want everybody to have the most up-to-date information and findings if they’re going to try to do something like this, buttt….
Second, I’ll reiterate my disclaimer again that I don’t advise anybody to do this, certainly not the trial and error way I put it together, it’s all a toy for me, and I make no representation about the road worthiness or load handling capability, especially if someone put a serious load on such a thing. I have a unique combination of engineering experience, hands-on, mechanical and fabrication experience, experience with trucks and trailers, etc. that makes me feel comfortable with what I’ve done. But in this posting, there is certainly not a design for others to duplicate.
But it is a blast!
I forgot to put in the picture of the special equipment I used when I was measuring everything, as well as a couple pictures of the damage.
On the right, that’s an every day pair of dollar store needle nose. You can’t have enough of them. Spread out across your workshop.
The red bar and pointer device is a premium SW&CH hitch level and alignment tool sourced from the SOM. (scrap wood and coat hanger from the shed of miracles). A scrap piece of a 2 x 2 pressure-treated stake, and scrap pressure treated 1 x 2 painted red from a different trailer project. The 1x2 was measured, centered, and notched to sit level across the bed, with the 2 x 2 at a perfect 90° angle to sit in the tightly in the coupler at deck level, fasted with a couple of scrap screws from my scrap screw bowl. I did use a good sheet rock screw for the pivot point.
I actually switched to a full-size coat hanger and cut it up and straightened it with a loop on the end because the white one in the picture was a drop scrap from a coat hanger partially used from who knows what, that was about a half inch too short.
It seems silly, and I presented silly, but A lot of getting the job right is the right tools even if they’re not commercially available. Of course I use pressure-treated for durability so it will last between the tractor trailer projects..
The only thing I can say is, when you blaze a new trail, there is going to be bumps and scrapes along the way.
I went to the driveshaft shop today. They got the two piece driveshaft installed properly to eliminate a vibration.
I was surprised that they just jacked up the truck and got underneath it to pull the driveshaft, no floor lift. When they did it, they put the jack underneath the rear differential, which is on the front rear axle.
These pictures from the sides show how much up and down motion I have on that back axle on the four link set up. You can see here how far the back axle can drop down if the front axle goes over a curb, and I already know that when the back axle goes over a curb, the tire can rise up to scuff the inside of the fender, about 8 inches, and I never lose traction on the front axle. Just a reminder, the four fenders are mounted directly to the truck frame, and the back axle actually pulls behind the truck on a four link set up that allows free up-and-down motion. I control bounce when it is not loaded with the same rear shocks I have on my Lincoln town cars.
View attachment 128043View attachment 128044
Now that we know how much articulation that monster has we all fully expect you to put 35s on it and take er to Moab..
We need a bigger laugh emoji.
Technical afterthought on the design. On a real fifth wheel stand axle, the fifth wheel is centered between the two rear axles, maybe with a little bit of forward and backward adjustment to balance weight on those two axles.
On the Road Ranger, my “5th wheel” is actually mounted on the top of the four link system, just a little bit in front of the rear axle. So all the weight is primarily on that axle and the two trailer axles,
I really haven’t done much with the Road Ranger since last summer, mostly for health reasons. Carlisle Ford Nationals are in a couple weeks, almost 1000 miles for me one way, so the last week or so I’ve been going all around the truck and seeing what I need to address or upgrade. I’m hoping to avoid an all night affair like the last two times I drove up. Here’s the list so far.
Priority “have to” items:
I had a tiny antifreeze leak that I couldn’t find for the last six months. The new brunette is about 45 minutes away, over an hour during rush-hour, and now that the temperature has warmed up, I looked under the hood when I got there, and I found the leak. A pinhole on a heater hose. That’s already fixed.
I measured all the geometry I could think of when I fabricated the fifth wheel, and then the trailer tongue, but in use, when I first went up north, part of the trailer tongue assembly could still scratch the top of the back fenders of the truck. I redid that tongue assembly when I got back two years ago, but now I have a scuff right above the tail lights on either side of the fifth wheel opening. I’ve modified a few things, it barely touches now when I go over some kind of hump on an angle, but I think I’m going to use the cut off wheel and just trim about a quarter inch off the tongue brackets where they contact the Aluminum light housings. I’ve got a couple of options to modify the light housings if that doesn’t solve it. Remember the “light housings” are really the corners of a cross bed toolbox that I cut out and flipped over.
The next priority is the spare tire on the truck (235/75/15 ), and one of the two spare tires for the trailer (185/65/14). Slow leaks. The truck spare is obviously placed high and very exposed. The one I have looks like it’s brand new, except it’s got some cracks in the side. So it’s got to go, but I want a good looking tired because of its location. I have two in the tire pile I will dig out, but if they’re not good enough and pretty enough, I’m going to go salvage one somewhere.
I have the spare trailer tires on OEM Ranger spare tire carriers that I mounted sideways on each side of the trailer up by the front legs. One has a slow leak. I’m either going to figure it out and seal it for good, or just swap it with one of the six or seven replacements I already have for other projects planned.
“Want to” items.
I’d like the CB to be working much better. The two pretty antennas I first put on interfered with each other, too close together, so I added a third one in the middle on a separate cable to the back of the radio. After doing some homework, it appears that I could disconnect one of the duel antennas and just work off one of them. So I took the third antenna off, disconnected the passenger side antenna, and tried the CB on the driver side only.
It gets out, and I can receive, but not like it’s supposed to. At this point, I suspect it may be the radio itself. It’s a 90’s vintage period-correct cobra 29 LTD. I have two other cobra 29 LTD radios, so I’m going to bench test them in the garage, but basically swap them and try them for a week and see if any one performs much better than another. I also have a 148 SSB, but I would have to modify the mount since it’s about a half inch wider, and then I have a pile of small CBs, but I really want the look of that 29 LTD in the truck. I don’t know if I’ll have time before nationals, but if none of them are working properly, I may send a couple out for repair, or I know I can buy a brand new one for about $115 when they have them on sale.
I have everything I need to install trailer brakes on the two trailer axles, and to install brakes on the tag axle on the truck. Rolling it all around in my head for the last couple/three years, I’ve realized I probably have a better than average jackknife possibility. When I removed the bed from the truck, that took a lot of weight off the drive axle, and the way I have the tag axle, it is not supporting the truck at all. Without having brakes on the trailer, to drag it back behind the truck, if I went into a turn and hit the brakes hard, the trailer would probably push me in a jackknife in a heartbeat. I don’t think it’s a serious issue if I don’t have the trailer loaded, if I just drive carefully. It is one of my top priorities, just probably won’t be done before Carlisle. Personally, I think brakes are just a crutch 😂
I’ve never been able to get my low intensity strobes working properly on the trailer. I have them all the way down both sides and across the back. I’m suspecting I may just have too many lights, that the controller might be too lightweight, without the power to run them all. If time allows, I am going to rewire them (they are very accessible), and if that doesn’t work, I have to find a more heavy duty driver. probably won’t get done before National’s.
Almost a year since my last update. Things have been slow with the bad nerve in my elbow, the surgery, and then all the physical therapy. I bought a bunch of parts while I was sitting around.
I bought a cheap tiny 300 psi compressor. All I originally wanted to use it for was to pressure up the little air tank on the outside behind the cab, next to the toolbox, that looks like a semi fuel tank. I have a long hose to plug in there that will fill up any tire on the truck or on the step trailer.
I was going to permanently mount it in the toolbox originally, so I had already put a switch in the overhead console in the cab above the CB, and ran a wire back to the toolbox. Now, when I got around to actually doing it, I wanted it mounted to do that task, but I also wanted it portable in case I needed to use it somewhere else.
I cut a small piece of diamond plate, slotted it for the compressor to slide into it, and folded up the two sides of the slot. Then I bolted it through the top of the toolbox. I had to splice the hose to make it long enough to reach the air tank, but I decided to just set it up with alligator clips that clamp on that second battery.
I also made a little ear on the bottom so I could coil up the air hose and the electric cable when I wasn’t using it. It’s placed so it folds down in the hole between the battery and the outside of the toolbox. The alligator clips are on a two prong mirror plug like you get on a battery charger, so I can use those clips for other things.
Item two: With my advancing age, my night vision is deteriorating. When I went back-and-forth to the Carlisle Nationals and a few other long trips, if it was hilly or curvy or foggy, I had trouble seeing ahead at speed, so I wanted some powerful low level driving/fog lights.
I bought a replacement valance that holds fog/driving lights a while back. I’ve had some halogen fog/driving lights for 30 or 40 years. The diameter of the holes in the valance were exactly the diameter of the amber lens, but the screws that held the lens on on the top and on the bottom wouldn’t fit. So I notched the two holes, and then you almost had to force the lights into them. And you’ll never guess, but I gave it a good coat of semi gloss black rustoleum.
Before
With the bumper off the truck, I removed the old valance and went to install the new valance on the bench. The new valance is open in the middle, so only the three screws on either end lined up with the old valence. When they molded it, it wasn’t exactly perfect, so it was bowing funny in the middle. I had to bolt it into the bumper somehow.
Coincidentally, there were two holes in the bumper, about 3/16”, that lined up with holes in the new valance, at the outside of the wide opening. I drilled the holes a hair larger, and then tapped them with 1/4x28 tap since I had a couple of those bolts. I used some scrap 1/8” diamond plate to make a couple elongated washers/ears (like the load spacers on a rocker arm cover bolt) and it worked like a charm .
While the bumper was still on the bench, I used a short piece of unistrut to make a bracket to hold the fog lights. They had a hinge clamp with a single bolt that went straight up. I used a couple existing bolts in the bumper to mount it to the back of the bumper. I had to slot those holes in the unitstrut to get a little up-and-down motion to get the lights to line up correctly. I put the existing bolts back in the bumper with a washer that was cut down on one side.
I couldn’t put the bumper back on the truck my feeble self, laying on my back, without knocking my teeth out, so big thanks to @Peter_'86_2.9L_Auto who came by for an hour and just helped me hang it on the four bolts on Sunday. Tonight, I leveled it up and bolted it tight.
I pre-wired the lights on the bench and left a long lead to wire them into the truck once it was mounted. Since I didn’t use the lead from the overhead console I put in for the air compressor, I’m going to use that switch and wire to run to a relay to work these fog/driving lights. I did just push the wire down in the hot battery terminal just to make sure they were working. When I finish the wiring, I’ll set a time that all you guys could look south, and I’ll flick them on and off. They’re pretty cotton pickin’ bright!!
I’ll post better pictures tomorrow.
Now that I finally got it it running right, after it sitting for seven or eight months, a lot of the tasks have been routine maintenance and all the tuneup stuff was done while I was trying to figure out why it had a miss under a load. Soooo, it’s been running great for about a week, and today the check engine light came on. 😤😤😤. I’ll reset it in the morning and see if it comes on again, and if so, I’ll head up to AutoZone to plug it in and find out what it’s unhappy about now. The good news is it is running like a top again.
I was having some weird problems with some of my strobe lights, and the airhorns, and I realized that the marine battery I have in the toolbox was under charged. Both batteries got very weak when the truck was sitting around, and I put a charger on the front with the two of them connected, but I don’t think it ever charged up the second marine battery. I had that battery on its own charger today with the two disconnected from each other, and everything started right. I’m not sure if that old battery is dying, but I’ll get a new one if it is. One concern is that I have one of the automatic cut offs in the circuit between the two batteries, so if the truck isn’t running, and I’m using the accessories, the second battery will automatically cut off from the truck battery so the truck will always start. It’s supposed to automatically reconnect when the alternator comes on, but I think it works so it won’t kick in and start charging the second battery until the front battery is fully charged, and I haven’t driven it long enough for everything to get charged. So starting tomorrow, I’ll have a full charge on both batteries when I head out, and I will monitor them as I go.
So now that I put a couple hundred miles on it, I just cleaned up some sloppy work I had done before with the wiring, and the wiring to the new driving lamps/fog lamps now that I have them focused in.
Since I first built it, I could only find one 20 amp circuit in the power box under the hood from the ignition, and I’m wiring several things off that. I tapped it from the hot side, and then put in-line fuses to the various contraptions I attached, but I was never happy with that. So today, I ran a hot wire from the battery through a relay to feed those various contraptions, and that relay is tripped on from that circuit that came from the 20 amp power box fuse. I have a similar set up on the twin air compressors for the train horns, and for the halogen fog/running lights I just put in. I used illuminated 20 amp and 30 amp switches in my overhead panel, but I think I’m going to add a couple more relays just for safety and reliability, although I’ve never had a problem.
One of the things I’ve done with my trailer lighting is to put a couple of indicator lights on the front corners of the hood for the turn signals and for the brake lights that are actually fed from the circuit to the trailer, which I keep fused. When the trailer lights aren’t working, the lights on the hood won’t work.
Back in the day, I’d pick up the top of the hood indicator lights off the Mopar cars. They were relatively rectangle in shape, and kind of went with anything, good looking pieces that were held in place with one screw from above. There was a little plastic housing under the cap that held an amber light with one wire, the housing being the ground. I used to pick them up for $.50 or a dollar apiece by the dozen. The last two pair I found, which was a few years ago, they wanted over $100. So no more more mopar lights!
On my Towncars, there is a vinyl trim piece that goes across the back top of the roof on the signature series cars that have the full length canvas or vinyl roofs. The end of that vinyl molding is held in place with a pointy solid piece of stainless with a screw through the top, very similar to those Mopar lights. So I picked up a few from the pull apart when they had them.
I have a drawer full of raw LED lights with leads on them. I picked out two Amber indicator lights that are probably 3/16 of an inch in diameter, and two red lights that are maybe 1/4 inch in diameter. I took a piece of fungible but firm, dense foam, cut and trimmed to fit under that stainless cap, and then used a little stone grinder on my Dremel to carve out holes for the two LEDs. I made them a mirror image, so the brake lights are on the inside side, and the turn signals are on the outside side. I put it all together with some E 6000, I clamped them between a paint star stick, and the tabletop to let the glue dry Then I used some black gasket maker to blackout the open side that holds the two bulbs. It actually came out pretty nice, and I put those on today.
& They’re working great!
Next, I used a couple of small pry bars and a paintbrush with most of the bristles cut off to pry down the Rolls-Royce tire and insert a little black RTV inside where the bead sits. Then I dipped the brush in mineral spirits and worked it around. I did it on both sides, where the beads sit, since half of it was weeping leaking, so I just did it all. It held 35 psi in the sun until I came in a couple hours ago, so I’m keeping my fingers crossed. I’ve done it before.
I’m totally frustrated with the CB radios, but there’s a method to the madness to rework the antennas. When I mounted the spare tire high on the passenger side, it blocks the view of the side of the long trailer when I’m just cruising down the road. Flip out/wider mirrors have been on the want list for a couple years.
I had a couple of flip over & out mirrors from a 70s Chevy, but that three-point bracket wouldn’t work on the 97. I looked at the ‘87 mirrors, and just swapping the heads, but the ‘87 bracket didn’t reach out far enough. I looked at other year brackets, and nothing would work.
I finally stumbled up on some early/mid 90’s full size Ford truck mirrors (like my ‘96 F250) on a similar bracket to the ‘87, that reached out about 4 more inches. The Chevy flip over and flip out heads worked in exactly the right place. With the mirror folded in, the arm is only about three or 4 inches wider, the widest spot on the truck. I haven’t hooked up the trailer yet, but I’m positive when they’re flipped out, I’ll have no problem seeing the trailer behind me. Btw, the Chevy heads are made out of fixed stainless steel rod that’s been drilled and tapped, and the sheet metal around the head is twice as strong as any of the new stuff you can buy, virtually bulletproof Now I have to get some bubble blind spot mirrors that will rise to my cool factor. I’m going back-and-forth between an oval mirror that will take up part of the full-size mirror, just a 3 inch round bubble, or maybe an independent Blindspot mirror on its own little bracket. I just have to get used to these to them figure out where I might put those.
Right now, I’ve got a lot of mirrors!
For the old mirrors, at first, I’m just going to take the mirror heads off. I’ve been toying with the idea of running 3 or 4 foot CB antennas on those mirror brackets, but I think it would be awkward. It’s worth a quick try just to get a visual. I’m probably just going to cut off the part that extends out, and plastic weld or fiberglass a good looking modification, maybe something that holds a small “Ford trucks” look logo or something like that. Haven’t got that far yet.
For the antennas, my realistic thinking is to simply move the custom antenna brackets from under the back window to high on the side of the truck at the back of the cab, with the overhead radio broadcasting off one, and the backup radio broadcasting off the second. I’d use three or 4 foot antennas. They wouldn’t be used at the same time obviously. But I’m definitely going to have working radios by the time I go to the Ford nationals!
So those antennas of the next step after I remove the mirror heads, and then I’m gonna shift my efforts to clean up and improve the step trailer.
I like how you did the indicators. I've been toying with some ideas to do the same thing. And my initial thought was stealing the indicators from dodges. But you kind of ruined that for me. I didn't realize that LEDs that small were available. I bought a bunch that fit a 3/4" hole and was planning on making something out of conduit. I may look for the ends and LEDs you used.
A few tips. First and last, if you do the same thing, slide them a little closer to the windshield than I did. I actually have to pick my head up a little bit to see the one on the right hand side.
Those stainless caps are nice and heavy duty, solid stainless steel. They had them on the Lincoln Towncars, some Crown Victorias, and some Mercury Monsrchs, 70s-80s ish.
Get the LEDs on eBay. It might take a few days to get them. In your search, if you change the search location to North America, you can get them 10 times as fast. Don’t order two or three - for $5 or $10, you can get 20 of them. You can buy a couple of sizes and a couple of colors from the same vendor if you just check with them in advance with a message, and save money there. I’ve got a drawer full of all kinds. Make sure they’re 12v, get them with the leads. Don’t get them without the leads, and don’t get them if they need resistors.
5mm is .2”, and plenty bright enough. The leads that are on the LEDs are like twice the size of a human hair. I’ve learned the hard way to get some 18 or 20 gauge wire, tin the ends first, and solder it to the lead about 1-2-3 inches off the LED. Think about how it will hook under that stainless cap, travel through the hole in the hood, and travel under the hood Then use the white shrink wrap on the individual connections, and I use a bigger shrink wrap that tucks into the stainless head and runs about an inch down the leads to protect them from the hole in the sheet metal.
BTW, I soldered about 5 feet of 18 gauge wire on mine, long enough to make my connections after snaking it here and there through the channels in the hood. The damn things are fragile, so bench test them over and over and over again as you work with them before you do the final installation.
A secret between just you and me. I took an old 12 V DC power supply from a computer or who knows what, clipped the end off, and put a couple tiny alligator clips on it. I put those clips at different lengths, so when they hang down, they won’t short against each other. I leave it plugged in at my workbench all the time. It’s perfect for testing low amperage things like the LEDs. Don’t tell anybody.
I used some dense foam, and then cut it to almost the exact size very easily with a bandsaw, I even chamfered the top, so it fits snug in the stainless. When I was poor, I did it with a handheld saber saw upside down, locked in a vice. I used a Dremel grinding stone, a hair smaller than the LEDs, to cut a groove in the foam. On the bigger LEDs I used, I flattened out the clear plastic flange on the LED itself, but if I had it to do over again, I would’ve just used a smaller LED. It takes a steady hand, but you can master it in about 10 minutes.
When I laid the LEDs in the foam, I kind of bathed it in E 6000/goop, foam side down, and then I pinched them on the table top with a piece of wood and a C clamp so it would all dry in the correct shape. I used a wooden dowel to push the LEDs into the exact position before the glue set, I wanted them flush It doesn’t have to be tight, it just has to be snug until the glue sets. When you pull off the C clamp, the foam will still expand a hair, which is perfect to bolt it on your hood and have it seal. When the glue set and I pulled them loose, I used some black gasket maker (because I was out of black silicone), but I just smeared it across the face to make it look finished. I used the piece of cloth (like flannel shirt) on a flat piece of wood and rubbed the face to take the silicone off the eyes of the LEDs. Then I let that set and then I buffed it again with the flannel cloth. You can be super messy, because those stainless caps are solid, and then I just used a little wire brush on my Dremel to polish them up without knocking anything loose.
I drilled a pilot hole for the stainless screw, and a 3/16 inch hole for the leads. When I did the 3/16 inch hole, I went all the way through the hood and through the bottom layer of the hood. Then on the bottom side, I opened it up to about a half inch hole. That gives you a place to work the wires down the channel in the hood. I used a wire coat hanger as a fish tape. In a week or two I’ll clean the underside once I’m sure it’s all working OK, and put a little square of aluminum heat duct tape on it.
Important: when I laid the two LEDs in the foam before I glued it, I put the negative/neutral in the center snd the hot leads on the outside. Don’t assume red is hot and black is ground, these things are from China, check them. I bent them carefully with a needle nose, so they would curve around where the screw goes through. That way, if you nick a lead with the screw, you’re nicking the ground. It’s a lot of stuff in a little space.
Having done this about a million times, the biggest pain in the ass is the hair-like leads on the LEDs break or pull loose. I don’t try to solder right up against the LED which causes other problems, but adding some decent size wire from the start avoids a whole lot of headaches.
What do you think of my novel so far? This is probably way more info than you need, but I kind of write it for anybody, for somebody who may not have ever done something like this before. I use wire solder, not plumbing solder, and you need the paste so the solder takes, and I tin the leads first (putting some solder on them just laying on top of the workbench before I try to connect them). That way you only need four or five hands.
And I hesitate to tell you this one, but clip off the end of the leads that come on the LED before you try to strip them. They’re usually tinned/leaded, and the wire is so fine that when you try to strip them, you just rip the wire apart because the little bit of solder won’t slip through the insulation. I say I hesitate to tell you, but what the heck. I’m not going to be standing there laughing while you pull your hair out ripping the wires apart and wondering why they won’t strip!
And be careful putting those LEDs here and there, it’s addictive, and very easy to get hooked for life!
I hope it helps!
View attachment 141599View attachment 141600
View attachment 141601View attachment 141602View attachment 141603
Mirrors, CB radios & antennas upgrade update:
Mirrors: So far, I’m loving the fold out stainless mirrors. They’re heavy duty stainless from the 70s, not the thin tube crap they make now. They’re sitting about 4 inches closer to the rear of the truck than the OEM mirrors, and about an inch lower. That doesn’t sound like much, but it’s actually taking some time getting used to - when you’re driving down the road, your head looks in the wrong direction - but the field of vision is much better. I’m sure I’ll get used to them in a week.
I put a 3 inch round wide angle mirror on both of them, the kind that you can rotate to change the angle. It’s working perfectly for the driver side. On the passenger side, I see a bigger field with the main mirror, but I need more, and I’m not liking the 3 inch bubble. In the box-o-mirrors in the shed of miracles, I had a 60s-70s rectangular wide angle car passenger side mirror that used to be remote controlled (Towncar or ???). About 3-3/4” x 4-1/2”. If I flatten/sand down the ABS plastic back on the 8” belt sander, and glue it onto the new mirror head, I believe it’ll take up about a third of the mirror head and work right side up or upside down when I flip it out, and provide a nice wide angle view either way. That’s still a work in process.
Antennas: I took the OEM mirror heads off of the OEM mounts and got creative. The mast/swivel mechanism mounts up through the bottom, held with three screws.
I used that plastic piece as a template to make a couple of 3/16 inch thick flat aluminum plates cut from the web of a scrap 4” channel. My plan was to drill out the center and mount the antenna there. I started with a small hole, and added a 6 inch long 8/32 bolt I had just to check level and tilt. They were leaning way too far inwards, and actually leaning forward instead of straight up instead of vertical and a little backward.
Then I got more creative, I cut them out of the flange on that 4” channel which is about a quarter inch on the outside, but about 3/8 where it folds into the web, basically the same piece, but a wedge. After some trial and error, and remaking them twice, which didn’t take too long, I think I finally nailed the angle. I used a spade bet about an eighth of inch larger in diameter than the antenna spring to take the taper out of the taper side to mount the antenna, and then drilled the hole out.
I rerouted the radio wire from the radio down by the stick shift and brake controller to the right door, and the overhead radio to the driver door. I snaked the wire through that black rubber accordion piece where the door opens and closes, and then I had to drill holes internally in the plastic mirror mount to snake the wire down to the bottom of the spring in the hole. I used a crimp big ring, and connected the signal wire at the top of where the spring mounts, between the plastic grommet and the spring. The ground wire went to the aluminum chunk that holds the antenna with the isolation washers above and below. I actually made the first pair work, but it looked like I made them with a chainsaw by the time I got them at the correct angles, so I simply duplicated them once I knew where I was going, and I think they came out really nice.
The oddball aluminum blocks show underneath the black abs plastic just about an eighth of an inch. Once I’m sure it’s all working, I’m just going to put some semi gloss or a flat black rustoleum on them. Overall, I’m loving the way they look. The tilt inward a little bit, and tilt backward just a little bit, but almost vertical both ways, perhaps the hardest part was to get them to match. I liked the appearance of the location behind the cab better, but these should work infinitely better for the radios, and I still think they’re pretty cool, and I didn’t have to fabricate something to close up the hole where the OEM mirrors were.
A question for @sgtsandman, or should I say @sgtradioman (or anyone who knows): As far as performance, I’m not seeming to be able to get out on either one of them, but I didn’t try very hard. I have my #2 Cobra 29 LTD classic with a side mic mounted overhead to the driver side antenna, and I have the Radio Shack holy grail TRC-465 single side band between the stick shift & the brake controller, and in the front of the driver seat. Again, no joy, but both of those are craigslist/marketplace radios and I’m not sure they’re working properly. I have to climb up on the garage roof and clear a vine off the 102 inch whip. I have up there with a proper ground plane, find a radio that works, and then test the antennas with that radio.
The general question: 4’ fiberglass antennas are/could spring. They are mounted 6” out where the A pillar is the only metal, and it tolts away at a 40° angle +/-, ideal, ground plane, theoretically, so that should actually assist as the ground plane, y/n?. They are even with the top of the hood, and of course, the cab is glass, other than the A pillar. The routing of the wires is in quite 18 feet, maybe 12 feet, but I did squiggle them back-and-forth instead of coiling them. They start high or low by the center of the windshield, and they’re routed to the back of the cab under the carpet and then forward again and up into the doors. Continuity is correct from the center pin at the radio to the spring on the antenna.
I’m going to check everything again this weekend, and if I’m not getting performance, I’m got my to take a radio that I know is working properly and try it. From my feeble understanding, the antennas in this placement should work fairly well, especially broadcasting/receivibg forward of the vehicle is my primary desire.
Other upgrades: The 5yr old free 24M-1 marine battery I got with the $93 truck, that I have in the toolbox as my second battery, gave up the ghost, so I bought a new one. I got about 30% off a new old stock battery made in February 2024 ($90 bs $140), and it seems to be charging up just fine. They doubled the one-year warranty to two years. It was never used, just never sold. They were all about 150 or $160, and I have 90 days to bring it back for a full refund, but I think it’s going to work just fine as the backup battery.
Then I adjusted the muffler/tailpipe hangers, cleaned up some of the wiring when I pulled the old CB antenna wires out, replaced one of the stop/tail/turn marker lights on top of the headache rack, etc., etc., a bunch of little things. Best news is it seems to be driving just fine.
Next I’ll tackle a step trailer, but it only needs erector set set type of clean up repairs, probably won’t take a day. Then I just want to drive around with them a little bit because they’ve been sitting so long. I’d rather have any adventures here and in the middle of West Virginia like last time.
