DR, the coils that my Ranger is sitting on in the pics. ARE the F150 coils (stock height). I am using the shocks and the weight of the truck to hold the axle in place. There are wheel chocks behind the tires to help keep it from moving, but the Jackstands ARE going back under it, as this was done to show you what kind of clearance you DON'T have with the F150 coils. Sucks, don't it? Having to lift it moderately high to clear the axle. I also re-measured to confirm my LCA length, and I am looking at 32", bolt hole to bolt hole. I am using bushing at both ends for the improved flex, not to mention the softer ride than a Heim or Johnny joint can provide. Hopefully, I can find some useable box or tube steel at the local recycler in the AM. I have steel on order again, but I am getting really tired of not getting the right stuff.
As for the EB coils over the F150, I feel that the Ranger, with a V8, is closer in weight to the EB than a FS truck.
Look at it this way, Dangerranger83. This is a GREAT time to go ahead and deal with any thing that you want or need to do to the axles while waiting on the rest of your parts. You know, weld the brackets on better, plate them, just make SURE to leave space for the bushings and the end of the arm in the axle mount for the bushing to be able to pivot, and the arm to be installed/removed. The brackets on the LCA mounts on this axle were welded on for AFTERMARKET/smaller than stock arms/bushings. MAKE SURE to include the space that your LCA setup will need when you armour up.
