The Deuce
Thanks for the kind words guys!!:headbang::icon_cheers:
those seats look so uncomfortable :P
Haha, they do 'LOOK' uncomfortable, I have to agree, but amazingly they are not, they're actually surprisingly comfortable for what they are. Not much to them and very inexpensive new. Under 100 for 1 seat with cover. I did add a chunk of 1" thick foam to the seat bottom tho. These things hug me quite nicely!
I have had them for probably 10 years or more and swapped them into several different rigs in that time and my only gripe is that they don't recline or fold forward, other than that I think they are a great seat for my needs and pocket book.:icon_thumby: Oh and they take a little more effort to climb into than the stock seats too, but any racing seat would, that is in the design of them, you can't just slide your ass in like a stocker seat, but meh, it's all good.
The stock Explorer seats are at least as comfortable or even maybe not as... but I have found the Explorers to be tiring trying to keep myself from sliding around on the seat while wheeling. These hold my ass right where it needs to be.:D
I'd love to get a set of Mastercraft reclining seats but they are out of my price range, maybe one day, but there are far more important things I need to buy for this project first.
I have been really thinking hard on the tranny swap, might just use my tax return to buy what I need, we'll see what the wife has to say about that tho, lol.
If all goes well I should have her up a wheeling again buy the end of the week. Can't wait to get out again.
I wish i could say that... Im hoping to get mine done by June. Right in time for Big Bear wheeling:headbang:
i lucked out with my Corbeau's. got both for $250.
Well, I got more shit done on the Bronco lately.
Finally did the ECM relocation I have been trying to complete for a while now. Actually went a lot easier than I expected it to.
First off I popped out the glove box and hung it down so I could get a better view of the new ECM location directly behind the glove box up against the the outside of the heater box.
The Deuce
Here it is folded down and uncut.
The Deuce
Not the best comparo shot but here it is after the cut. I cut out approx. 2 inches of glove box with this mod. I ran a cut around the back of the glove box and then trimmed it so I could slide the back half back into the front half making it shorter so the ECM can fit behind it. Then drilled and riveted it back together. Still fully functional too, only has a little less room now.
The Deuce
Here's the ECM mounted in it's new location. I was even able to use the factory mounting piece to secure it to the side of the heater box behind the glovey.
The Deuce
Here's an inside the glove box shot, as you can see it still functions as storage space and now allows room behind it for the ECM.
The Deuce
Here's looking up at the new ECM location from under the dash.
The Deuce
Also pulled the rear drums off to re-seal the axles, install the new wheel lug studs and clean up the back brakes. So I insert the key for the cheapo locking lug nuts I have on there and the drivers side just rounds off whats left of the key pattern inside the lock with very little effort....Damn, I knew it was coming as these locking lugs suck ass to say the least. You know the kind with the key that slides into a cut out pattern on the end of the lug nut. CHEAP JUNK IMO.
The Deuce
Then I grabbed my largest pair of vice grips to give that a try and no go whats so ever.....FAIL.
The Deuce
So then I start thinking grinder. Thought about trying to cut the lug off without damaging the wheel....yeah right hey, then I thought about cutting a big slot in the end of the lug nut and using my tire iron hub cap flat blade on it when it came to me..... weld another lug nut to the top of the locking lug nut.
So out came the Lincoln.
The Deuce
Weld spare lug nut on top of fubard locking lug nut.
The Deuce
Viola!! Spun right off without issue.
The Deuce
Installed all 10 new lugs in the back axles, cleaned up the brakes which didn't get any oil on them btw...Lucky. Turned out the diff vent hose/breather was plugged so it made the axle seals leak to allow air in and out of the diff during heat expansion, unplugged it raised it above the bottom of the frame and the axle seals looked good to go. While I was under there I rebuilt the rear drive shaft with all new ujoints and a CV rebuild kit, greased the hell out of the slip yoke as well.
On our last wheeling run, Baldy, I ran one half door on the drivers side and left the passenger side with the full door. Turns out the passenger side elec window motor had kicked the bucket so the window would not move at all. After messing around trouble shooting the problem and live wiring the motor, I came to the conclusion the motor is fried. Just so happens the half doors mechanical window parts will fit in place of the elec window parts. Figuring this will be a lot easier to swap doors when ever I feel like it. Unfortunately the mechanisms for both elec and manual are all riveted in. Sucky, so after pulling the door panels off and grinding rivits and swapping parts, I now have a manual window on the passenger side door.
This is what both doors looked like from the inside. Drivers door pictured.
The Deuce
This is how the passenger door looks now, I need to make up a small filler panel to go around the window crank still, but you get the idea.
The Deuce
Here's all the stuff I pulled out, elec window motor, elec window mechanical components and wire harness that went into the door for the power window/power lock/elec mirror/speaker/courtesy light. My power door locks have been seized for years, there's no spot for door speakers anyways and the elec mirrors didn't swap over from the Explorer and there courtesy light was just illuminating the inside of the door when the doors where open. lol. So really I didn't need any of it in the door at this point anyways, so out it all came. What a chore to feed that harness back out of the door and all the mechanicals only fit out in one position that I had to figure out on my own, was pretty frustrating at one point haha.
The Deuce
Since the drivers door elec window still works, I cut the wires at the door jam and just wired it in to a trailer plug on each side of the wiring at the door jam. Now I can just unplug the wires and swap the half doors on easy as pie.
Also did a gauge install over the last few weeks as well. Decided that the factory elec tcase controls on the dash that aren't used in my application would be a great spot for a couple gauges to reside.
Factory 91 Explorer elec tcase controls, my tcase is a manual tcase and these controls aren't used.
The Deuce
Popped the tcase controls out of the dash mount.
The Deuce
Cut out and bent up a small piece of sheet metal to mount the gauges into.
The Deuce
Cut and shaped to fit where the tcase controls originated.
The Deuce
Threw some satin black on it.
The Deuce
Drilled both the factory bezel and the gauge mount for rivets to hold the gauge pod in the hole.
The Deuce
The Deuce
Riveted in place and ready for gauges.
The Deuce
Gauges installed in bezel, don't mind the actual gauges, I'm using water and oil in this set-up but was easier to use the amp and oil for mock ups.
The Deuce
Actually installed in the dash with the proper gauge combo I need.
The Deuce
I also started on welding up some broken metal on the rear body of the Bronco as well. With the old crusty body mounts that failed before I replaced them, the body took the brunt of the abusive suspension flexing. The body mounts and bushings were shot and allowing the frame to flex with the suspension and in turn worked the body untill it cracked at the bottom corners of the back door/hatch. Those of you who watched me struggle with closing the back door/hatch will attest to how poorly it works. Well I started on fixing that problem too.
This is the drivers side all welded up, just need to get the passenger side patched up and welded back together and the rear door may actually work properly again.
The Deuce
While the drivers side had just cracked in several directions and places, the passenger side actually had rust issues as well as cracking. I'll need to make some patch panels for this side.
The Deuce
nice work, i wanna gut my electric windows as well and go to manual, i think i'm just gonna get new doors as i need a new paint job anyhow
Yeah it would certainly have been easier to get another set of matching doors. Only took a couple hours to swap over the guts from one door to the next, lol. Instead of 15-20mins to swap a whole set of doors on. I would have went that route had the second set of doors I had been in better shape.
On another topic, I might have to build an anti-wrap bar now, my rear Exploder springs are starting to exhibit slight wheel hop. I'm thinking of using one of the stock 76-79f150 radius arms I have kicking around here. Usually once wheel hop starts, it only gets worse as you bag on the rear springs.
Mind you, I have 3" lift blocks under them rear Explorer leaf springs and to get them blocks out of there would give a bunch of leverage back to the spring pack. Maybe give them back the ability to control wheel hop better. Just need to figure out what route to go to keep the lift height I have when I ditch the rear blocks. I do still have the stock 86BII shackles out back, longer shackles would free up some flex but I would need a 6" longer shackle than what's under there to gain 3" lift lost if I remove the blocks. Not to mention the pinion angle would prolly change and need re-aligning....cut leaf perches off and weld back on at the correct angle again. My leaf bushings look to be in need of replacing as well, could be they are allowing the diff to move slightly and inducing wheel hop?
Maybe I should get working harder on gathering parts to link the rear. Rear flex is marginal at best under there, it would be nice to have at least a 60/40 front to rear flex ratio, tho 50/50 would be sweet. I think it prolly has 75/25 right now.
I'll keep y'all posted either way.
Well, if you build ladder bars to go underneath the rear end, your rear flex will be even more marginal depending on how you do it. Go look up CopyKat's BIV build, he used F-150 hangers which dropped down the suspension a bit. If you were to do that and run say a Belltech 6400 shackle set, it would definitely get you close to what you're hoping for. As far as pinion angle goes, it shouldn't be THAT bad, so just run some pinion shims.
Hey thanks Andres, I'll go back and re-read CopyKats build again.
I have built several anti-wrap bars over the years, basically a triangulated tube system that prevents wrap and mounts to a shackle at the frame, this style won't limit suspension travel at all.
My thought was to hard mount the rad arm to the diff and then build a shackle system to mount it to the frame so it can move with the arc of the springs and not bind throughout travel.
I have a CV rear drive shaft so in all reality pinion angle is negligible.
We'll see, I like the idea of different hangers to relocate the springs lower on the frame, too bad I just tossed out the back half of an f150 frame about a week ago.
Actually this reminds me, I was thinking about relocating the spring hangers under the frame at one point, maybe I should look into that some more as well.
My plan is links eventually, so I don't want to spend a lot on the leaf set-up if I can help it.
I should really start buying Johnny Joints, 8 feet of 2x2x1/4" and start building the rad-arm rear already, Want to basically copy the front for the rear.
So many other things I would like to buy for this project before I link the rear tho. :(
Namely 5.13 gears and 100feet of tube for the exo to start with. :D Need cage soon... before I flop this thing.
Was in the back yard doing some Urban ditch wheeling when my buddy asked me if it could drive up a tree, so we tried it out. Could have climbed right up and onto it's roof, lol.
Short clip of the idiocy.
http://www.youtube.com/watch?v=v1ChCR6H17Q
Hey Bones! Just came back through the thread looking for how you chopped your fenders. Did the same cut on my BII I just picked up, and thought I'd say I still love this rig! Anything new on it?
i just looked through your thread, nice work thats a sweet rig you got there
Thanks guys!
I entered in the mud bogs here in town at the beginning of Sept. and came in second place in the 'stock rig 38-44 tire class', friggin amazed me all to hell!! I was up against fullsize rigs with V8's and larger tires and I actually beat them. Consistently ran in the 9 seconds which over the 2 day event gave me second place. Pissed off a few of the big boys too, lol. Made my year!! I paid $50 to enter and threw $50 fuel in it and won $100 and a medal, Hella sweet!!
Here's a clip from the bogs. The guy I'm racing has a healthy sbc with 350+hp ( so he said) and 42's under his Cheby. The mud was diff dragging all the way and sloppy clay like mud.
http://www.youtube.com/watch?v=7m7IiuD-5OM
Still can't believe my little 4leaker and 38's beat the V8's and 44's tho.
Here's my buddy in the silver Chev on 40's with a real healthy sbc trying the same lane in the vid above. Still not sure how I flew through the mud that fast and the big boys bogged down. Mind you my 38's are only 12.5 wide and all the big trucks had very wide rubber, maybe that helped me cut threw the mud? My 1/2 ton diffs and 38's maybe had the same clearance as 44's and 1tons, maybe my power to weight ratio is similar as the big heavy powerful trucks?? Who knows, but she did very well and was the crowd favorite all weekend!! The green ford he's racing is who got 1st place in my class, he ran 38.5x11" boggers and had a claimed 490hp from a big block 460, the limit for stock class was 500hp. He ran in the 7-8 seconds consistently.
http://www.youtube.com/user/CBONES4X4?feature=mhum#p/u/1/Aqsx4Nn0NDU
I've been wheeling it pretty much every weekend, beating it hard, she seems to be taking it like a champ!! Knock on wood, lol.
I think a couple of my tires spun on the wheel when I was aired down wheeling because I have a nasty shake at certain speeds now and then it's as smooth as glass at certain speeds. No steering wheel feed back tho, no death wobbler and any steering wheel wobble at all, it feels like the wheels are jumping off the ground as I drive, lol. As long as I keep in at the smooth speeds it's great, haha, but tough to do all the way to the trailhead. I even tried adding antifreeze to each wheel as some old timers said it will balance them.....NOT, it just changed the speeds at which the wheels shake.
I'm going to see if I can get them balanced somewhere, I have checked around a bit and no one is willing to try and balance 38's, tho I haven't called every place in town. I do have a new wheeling buddy that owns a shop here in town, just met him last trip and he said he'll give it a try on his balancer. Hope it works cause they shake real bad at certain speeds. Basically when I hit 80kph/40ishmph the whole bronco shakes and when I hit 90kph/55mph it stops shaking all together and then any faster and the shake comes back 10 fold. Frustrating because these tires used to be smooth all the way.
They were balanced with lead weights when I bought them, I noticed that 2 wheels now have no weights on them any more, that's the 2 that I believe are shaking now. Drivers front and passenger rear.....shakes the Bronco real nasty at those speeds.
One of the last couple trips I ended up puncturing the oil filter on the trail as I was crawling through a real twisty section. I started to see light blue smoke puffing up through my ripped shifter boot, smelt like something burning so I stopped and jumped out and looked under the Bronco to see flickering light coming from the engine bay. I quickly popped the hood to 2 foot tall flames jumping out the now open hood! Holy shit, so I started grabbing hand fulls of sand and threw it on the flames. Half a minute of this and I had the fire out. Burnt all the insulation off the heater box too. Once the filter was punctured it spurted a stream of oil onto the passenger exhaust manifold and promptly ignited. By the time I saw smoke there was little oil left in the engine. I was wheeling with a Yj and a Cherokee, the guy in the Cherokee had a spare filter for his Jeep 4.0L and the guy in the YJ had 4L of fresh oil. Turns out the Jeep 4.0L oil filter is a direct swap onto the Ford 4.0L!! Imagine that! Slapped the J##P filter on and tossed the fresh oil in a continued wheeling the rest of the day. That trip was a bad trip too, after the Bronco almost burnt up, the YJ spit out it's rear d-shaft and bent both front leafs and the Cherokee granaded it's front d-shaft and cracked the tranny housing and spewed all it's atf on the ground way out in the bush. We spent the next several hours limping the 2 broken J##Ps back out to the road where I towed both back to my place about 5kms from the trail head.... one at a time.
Some pics from recient trips.
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
The Deuce
looks like alot of fun out there :icon_thumby:
glad the BII is doin well for ya...
btw, what is the green tube monster based off of ????
l8r, John
