- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- 4.0 V6
- Manual
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
I got the second coat of regal red on the outside, and the first coat of the gloss black on the top and bottom. I drilled 10 holes in the bottom in all the pockets to let any water drain. I’ll smear some paint on those holes from the inside before I put the insulation and tub back in. I’ll touch them up with paint on the outside before I bolt it to the frame.
I want to drill another drain hole right underneath the drain valve. The way this thing is made, there is a raised edge about 2 inches inside the perimeter. I want to drill a hole at either end to let water drain, but I can’t access it from the inside, too much of an angle.
I got all the handles and hardware first coat painted with my homemade maroon.
