- Jan 14, 2024
- Gdl, Mexico
- 2.3L
- Manual
Thanks a lotThe needle just pulls off, put a fork under it and lift it off
But.................getting new needle calibrated is not always easy
You would think just putting new needle on pointed at 0 would be it............
And it can be, lol, but not always
So be prepared to hook the cluster back up, plastic cover off, you can leave speedometer cable off
And start the engine
See how Tach is reading
You can pull the needle back off with engine running and put it back on closer to correct RPMs if its off
Speedometer needles are worse, have to drive at a KNOWN speed to put the needle on
Always change the back light bulbs when a cluster is out, always![]()
Welcome to TRS
I would love to see a picture of that!My 86 did the same thing. I just cut a wire tie off the right length and super glued it on the center piece. Still on there to this day.
