2.5L ('98-'01) short on power, sometimes...
Featured Build Threads
eaglescout94
Forum Member
Law Enforcement
central illinois
Since I've got my 98 2.5L back on the road and handling daily driving duty's I've run into a bit of an issue that has me stumped. Most of the time it drives fine but I have other times where it loses some power for a bit but come back. I can hear and feel the difference, acceleration is extremely slow at that point at best. When it happens most of the time its after I shift gears, predominantly into 3rd or 4th gear. Ive noticed if I press in the clutch then rev it a bit its back to full power, otherwise it works itself out in 20ish seconds. I did plugs 3 years ago, plug wires i believe are fairly recent as well. Unfortunately my dad was under the hood in the last 3 years and I don't know what he's tried to "fix". Where would be a good spot to start digging into it? I've pulled codes and only thing is o2 codes
What O2 codes? That would definitely do something as it could be running rich or lean and would tell some of the story.
I’ve attached a pic of the codes. From what my scanner says it’s both rich and lean codes, an issue with the high side DPFE sensor hose.
  • short on power, sometimes...
How old is the clutch? When mine needed to be replaced, shifting into 3rd and 4th was when I noticed it was slipping. Pushing in the clutch, revving it probably cools it down enough to work again. Just a thought
I have no clue on the age. If it was slipping wouldn’t my rpm’s rise more so than usual. It seems to start at around 2,000 rpms
You'd notice a loss in acceleration first. But yea, if you then give it some throttle it would rise in rpm. Clutch is probably ok if it's at a constant rpm.
It’s acting like it’s dropping cylinders or getting weak spark is the best way I have to describe it. I pulled a couple plugs and they still looked good, I have new wires on the way for it. The sensor hose issue was easily resolved. It just came off the fitting.
My '00 Ranger sat for 5 years before I bought it. With new plugs and old wires, it would drop cylinders at 2-3k rpm under load. New wires went on right after and it never happened again. Also maybe check on your inertia switch and see if it's connector is getting hot.
Sounds like a plan. I’ve never replaced the wires and a couple don’t match anyways. I’d never thought to check the inertia switch but makes enough sense it could be involved as well
Got the wires changed, several lost the ends when I pulled them. Unfortunately the random power loss is still there. The inertia switch didn’t feel like it got warm. I’ll pull codes again when I get home and go from there. Anywhere else I should be looking as well?
Is there any way you can get the issue to repeat during the shift? Like if you short shift it and give it 3/4 throttle. Or at a certain fuel level does it happen more?
So far I haven’t been able to cause the issue to happen. I normally shift without using the clutch so I tried using it and it still happened at random. I was curious about fuel levels since 3 years ago I put a new pump in, not a complete sending unit, but it’s happened at near full all the way to close to a quarter tank.
The biggest constant seems to be it happens in 3rd and 4th although I’ve had a couple occasions of it happening in 5th and I had to down shift to maintain speed
Honestly man, you're describing the exact symptoms I had with my old 2.5 5spd. I even thought the booster valve was leaking and applying some brake during steady throttle. Turns out it was just the very beginning of the clutch wearing out. I babied the issue for months.
I'm not saying this is also your issue. I'm just familiar with over thinking stuff and convincing myself I'm on the right track.
It very well could be the clutch. I know my dad’s never touched it but the truck has around 240,xxx on it. Clutch is on the do list over winter anyways so I’ll keep babying it for now.
I've been putting off replacing my rear main seal because I dread removing my exhaust to pull the trans. Wish I still had a 4cyl and not this 3.0
Featured Ranger Based Vehicle
