2.5L ('98-'01) short on power, sometimes...
eaglescout94
Forum Member
Law Enforcement
central illinois
Since I've got my 98 2.5L back on the road and handling daily driving duty's I've run into a bit of an issue that has me stumped. Most of the time it drives fine but I have other times where it loses some power for a bit but come back. I can hear and feel the difference, acceleration is extremely slow at that point at best. When it happens most of the time its after I shift gears, predominantly into 3rd or 4th gear. Ive noticed if I press in the clutch then rev it a bit its back to full power, otherwise it works itself out in 20ish seconds. I did plugs 3 years ago, plug wires i believe are fairly recent as well. Unfortunately my dad was under the hood in the last 3 years and I don't know what he's tried to "fix". Where would be a good spot to start digging into it? I've pulled codes and only thing is o2 codes
What O2 codes? That would definitely do something as it could be running rich or lean and would tell some of the story.
I’ve attached a pic of the codes. From what my scanner says it’s both rich and lean codes, an issue with the high side DPFE sensor hose.
  • short on power, sometimes...
How old is the clutch? When mine needed to be replaced, shifting into 3rd and 4th was when I noticed it was slipping. Pushing in the clutch, revving it probably cools it down enough to work again. Just a thought
I have no clue on the age. If it was slipping wouldn’t my rpm’s rise more so than usual. It seems to start at around 2,000 rpms
You'd notice a loss in acceleration first. But yea, if you then give it some throttle it would rise in rpm. Clutch is probably ok if it's at a constant rpm.
It’s acting like it’s dropping cylinders or getting weak spark is the best way I have to describe it. I pulled a couple plugs and they still looked good, I have new wires on the way for it. The sensor hose issue was easily resolved. It just came off the fitting.
