rngrdngr
for my sas conversion i want to use coil springs in the front, i would like to get 10 inches of lift from them to.anybody know what type of springs will fit in the 99 frame coil buckets?
your going to be hard pressed to get a setup to even work with your stock buckets at all. they are the goofy in the frame ones right?
2x4 not 4x4My 99 does not have coil buckets (I have shock mounts if that helps)...am I missing something here?
i want the bottom of my truck to be level with the top of my tires.
The taller it is the more places it will goWhy?![]()
The taller it is the dumber it looks and the more likely to end up on its roof.
I don't know if there are differences between the TTB bucket and yours but, the TTB buckets and Skyjacker 7" EB coils equal about 10" on a SAS.
BTW If your gunna jack it up that high at least fill the well wells with a minimum of 35"s, not only would it look a whole lot better, but the bigger tires are heavier and with something that big you will need more mass down below.
Ok every time i read on here people always flip out when someone wants to use ttb springs for the sas springs.they say there way to stiff so you will have a rough ride.so if thats the case wont the 7in eb coils give me a stiff ass ride to?
