im going to buy a a dana 44 front end and rebuild it with ford 9in 60o steering knuckles from spidertrax. so besides the knuckles yea im rebuilding the whole thing. thats why i need coils,coil overs, air shocks because leaf springs get in the way.
Im going to take a stab at this post as it doesn't seem to use correct grammar. Your going to buy a Dana 44 front axle and then take the outer C's off and put on the Spidertrax Ultimate Knuckles? Is that correct? You do realize you would be better off just buying a Dana 60 as you would spend 1000 on the knuckle kit and another 650 on unit bearings for it. Thats 1650 with out the custom shafts you would need for the outers lets call it 2400 including stub shafts (spidertrax stubs are 400 a piece but then you would need custom inner shafts to work with a dana 44 carrier so it would be more in the 3000 dollar range to use those knuckles on your D44), you can buy and build a mild Dana 60 for that.
