Rough idle/miss (Video)
TheUgster
disconnect the IAC and see if it idles better...Maybe clean the throttle body and IAC. I had a rolling idle that would drop to about 450 RPM and i cleaned out the TB and IAC ports with MAF sensor cleaner and it idles much better now.( also only happened on cold starts) I cleaned the MAF hot wire while I was at it as well. you can always use the hard stop screw to set the idle real high so it doesnt stumble..haha
