- Jul 24, 2008
- New Orleans, LA
- 3.0L
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- Stock
The radiator, fan clutch and water pump have been replaced, the cooling system filled and checked for leaks. All electrical and vacuum connections are in place. Everything looks ok but while letting it run for a little while after starting it up, something seems to be limiting or governing the rpm range. After it warmed up I gave it a few deep pushes on the pedal. It revved up to about 3500 rpm then kind of stuttered and bogged down. It did not stall or sound like it was going to die, but it would not rev much higher than that. Holding the pedal down, it felt like the engine was shaking much more than normal, as well as making a whooshing, almost air sucking sound - different than the sound of the new fan clutch. I shut it off and looked for any vacuum hoses that may have disconnected but found none. I started it back up to listen but did not hear anything out of place below 3500 rpm.
I drove to work this morning for the first time in two weeks. I do not have to get off of local streets, so I did not have to run at highway speeds. Everything seemed normal but I did not push it above 3500. I will try to open it up on the way home this afternoon and observe what it does.
Has anyone had something similar happen? Should I be very concerned or worried? Two weeks without my truck was long enough; I don't want her to be down and not driveable anymore.
