- Aug 6, 2007
- Age
- 38
- Guilford, CT
- Automatic
Isn't the whine coming from the ring and pinion gears in the axles riding on the backside of the teeth?
No, it's the design of the gears in the trans. However, you bring up a good point that I was about to make. When you're in reverse, you're using the "coast" side of the ring gear, which isn't as strong as the drive side. And you're using the coast side on both the front and rear diffs.
