Rear end swap ‘02 and ‘06
Featured Build Threads
red78ta
Forum Member
Juneau
AK - USA
Vehicle
Drive
So my donor ranger (2002 broken frame) has a limited slip differential and the ranger I’ve been fixing up (4.0L sohc thread) has an open differential. So today I started the swap. Got the rear end out of the 2002 and into the bed of the 2006. I’ll take it into the weld lab to clean it up and inspect it at some point, but I’m sure between the two of them I’ll probably end up getting new drums/pads etc. I’ve got new leafs and shocks for the red Ranger I’m gonna put in too at some point.
  • Rear end swap ‘02 and ‘06
Should be pretty straight forward, just make sure the ratios match (first part of the bottom row on the axle tag on a cover bolt but worst case is swapping the front diffs which is an afternoon project...
Yup, they are both 4.10s So as long the limited slip one I pulled isn’t jacked up it should be simple.
Personally, I’d get at least a pack of new clutches and replace them in the limited slip. I’d also swap in an extra clutch disk on each side but I prefer them to grab and work more like a locker. Your requirements may vary.
Took the rear end in to the shop yesterday and laser cleaned it up, then wire wheel’d it, this morning I wiped it down with acetone and sprayed a “rust restorer” thing on. When that drys I’ll paint it and add a rubberized coating to non mounting surfaces.
I’ve got a clutch pack to install at some point, and brake parts on the way. Lots more to do :)
Did some black and red coats today and brake parts are coming in…
Rubberized coating drying now.
Okay, so looking stuff up online and trying to verify what seals/bearings I need, and per Napa I need the 2.5 OD / 1.6 ID for the 8.8; but I measure mine I get 1.4 / 2.25 which I thought was the 7.5….
Not that any of that matters right now bc I am having a crazy time trying too get the old bearings and seals out… gotta get a better tool to grip the bearings on the slide hammer
Ah ok I found the axle bearing section here and see that the 8.8 28 spline rangers use the bearings from the 7.5. Makes sense now!
Event Coverage
Featured Ranger Based Vehicle
