Rassan Frassan Wipers 94 Ranger
Andy D
Marshfield MA
to prevent Found On the Road Dead, Fix Or Repair Daily
I turned on the wipers to clear the wind shield. Nothing I guess I should start with the fuse. Where is it? For that matter where is the fuse box? :D
A liitle more digging and it is fuse 2 . More accurately, a 6amp cb, circuit brkr I'm guessing. Will it reset or do I need to reset it.?
WoW Andy!!!!
You must have a fully loaded 94. Mine are manual with crank on the passenger side so I have to have someone with me everytime it rains.
Heh heh I saved a set of vacuum powered wipers from my 54 IH van. But I used them on a '47 GMC :D
6 days later, I cleared off the Rat's hood. I figured I would have to jump because of the low temp and it has been sitting. a while. It started. The wipers parked as I turned the key. The Rat started and I let it run. The wipers work in all positions of the switch. The breaker must have reset. So I still don't where the fuse box is. :D
Wow. Now there's a question I bet Google can't solve.
Have you looked under the dash on the driver's side right over the parking brake pedal? Might find another one in the engine compartment - perhaps driver side, just forward of the brake master cylinder.
Or, maybe you were being sarcastic and I didn't catch it. If so, "sorry".
I was afraid somebody would tell me that. I suffered many sore backs messing around with Grand Wagoneer fuse boxes. And the Transit Connect work van. This is a cheap @$$ ,assembly oriented, location. Would it have been so hard to have put the fuse box a foot higher behind an access panel in the dash? :D
Personally, I like when they are under the hood as long as they are properly sealed against dirt and moisture. So nice to stand there with a meter laying on the fender or radiator support where it's easy to read while holding probes on terminals, etc.
Twice my '97's wipers got frozen down in the cowl, the next warm day they worked fine.
