Ranger 97-2000 cabs
Featured Build Threads
HalfMazda
5+ Year Member
Hey, I own a 2000 ranger that I rolled a few months ago. I'm looking for a cab and found a screaming deal on a 97' in great condition. However, I know that ford changed the truck significantly including widening the wheel bases after 97 and was wondering if the 97 cab is something that I would be able to make fit or if I should keep looking.
They might have lengthened it but I don't think they widened it.
93-12 beds interchange, if they widened the cab that wouldn't work. And they probably would have changed the interior too.
Regular cabs were lengthened starting in 98, so cabs from before 98 won't work. Extended cabs never changed.
Well>>>
The 97 back cabs can be made to fit with a little modification to the rear frame section bein moved forward by removin the 16 rivets in the cross member that goes across the fuel tank area. I measured a 98 frame to put a 95 cab on so I would get the independent from suspension, but sold the chassis before I started the project.
BUT, I believe the PCM is in a different location on the 97 back than the 98 ups.
GLWP!!!
Reader's digest version: Keep looking.
Glutton for punishment version:
The good news - the '97 cab bolts right up to the '00 frame!
If it is supercab, skip next section:
The not so good news - as the '00 cab was 3.5" longer, this leaves a gap between the cab and box. As chvlfrk said, you can separate the rear frame and shorten truck to remove the gap. Note: rear driveshaft also needs to be shortened by the same 3.5".
Alternatively, you could get cute and just put in a spacer, and no one would be wiser.
Resume for all cabs:
The bad news - the '00 has PATS, so without the dash from your rolled cab and then mixing the '97 wiring for lighting/etc with the '00 wiring for engine, the truck won't start/lights won't work. The silver lining is: The '00 dash will bolt right in in place of the '97 dash, so it is just a wiring exercise. However, without EV&T manuals for both '97 and '00, it would be a challenge.
Event Coverage
Featured Ranger Based Vehicle
