Lewis & Clark Ford Bronco II
Featured Build Threads
While we're dreaming, add a 4 cylinder diesel in there. Would be plenty for something elExolorer sized.
Cummins 4BT
Ford used the Mitsubishi 2 3l turbo diesel in 1st Gen Ranger.
If you were making a Camel Trophy Bronco II from the Ford parts bin, you could use the 2.3T diesel, manual transmission, a 1.5-inch High Rider suspenpension lift from the upcoming 1987 Ranger STX, and a 31-inch tire.
I'd bump up the boost and fuel on the 2.3T to give it a V6 torque rating.
Cummins 4BT
It is already pretty close to the 2.8 rating... which is almost half of a LR :icon_rofl:
Ford still owned their ag division then, it might be better to try to raid something out of there...
The 2.2L diesel was 59 hp @ 4000 / 90 ft-lbs @ 2500
The 2.3L diesel was 86 hp @ 4200 / 134 ft-lbs @ 2000rpm
The 2.8L was 115 hp @ 4600rpm / 150 ft-lbs @ 2600rpm
The 2.9L was 140 hp @ 4600rpm / 170 ft-lbs @ 4800rpm
The 3.0L was 145 hp @ 4800rpm / 165 ft-lbs @ 3600rpm
The 4.0L was 160 hp @ 4200rpm / 220 ft-lbs @ 2400rpm
The 1985-1986 Camel Trophy used the Land Rover 90 2-door which would have been the closest in size to the Bronco II.
The Land Rover diesel made 69 hp and 117 lb-ft torque. So the 1985 2.3L diesel (86 hp / 134 ft-lbs) was more powerful.
I was looking at 1990. I also mis-remembered how much torque the 2.8 had.
Defender was 109hp @3900 and 188lb-ft at 1800rpm
Range Rover and Disco made a little more, 113hp @ 4250rpm and 195 lb-ft @ 1800rpm
It looks like a later version (300Tdi) might have actually found its way into the South American Ranger after Ford bought out Rover.
Event Coverage
Featured Ranger Based Vehicle
