Had a danger ranger when i was in high school however it was a rusted out piece and now I have the urge for a little project. So picked up this 88 supercab for $300 off of the local craigslist not running. It is severe rust free as its a southern vehicle, just slight surface rust that can be almost wiped off.
20160717_084809_zpsw4pkva7g by Z S, on Flickr
20160717_084752_zpsmblokzvt by Z S, on Flickr
So after having the guy drop it off at the house for free I was able to get a closer look at it. It was sold to me as the guy bought it at an estate auction for a project but he was a auto mechanic and we all know they dont like projects after all day of working on others cars so he decided to sell it off. Has a clean title, not tried to start, dead battery, and locked column as no keys.
once i was able to take a look at it its been off the road for a while. Things i found missing front part of driveshaft, no starter or starter cable(odd), removed shifter....
20160721_163727_zpspojfoecd by Z S, on Flickr
well i looked at the clutch and it was brand new so looks like it was in the works of a new clutch when the guy died and everything got sold off. However you can see whoever was doing the job had no idea what they were doing as the clutch slave was stacked wrong with the spring in front of the throughout bearing... didnt find that till i got it running. To get it running i bought a new starter and cable, trickle charged the battery back to partial life.
20160927_132431_zps4jfvnubv by Z S, on Flickr
However it was missing a key part of the driveshaft so after scouring the interwebz for a one-piece later model driveshaft i found that the 2wd manual supercab to be a damned diamond in the rough and are rather hard to come by. So i purchased a later model 2 piece from a salvage yard as I will be swapping to the 8.8 rear later. Actually worked out as im still using the OEM early model 7.5 rear to work out the bugs. So the late model yoke slipped into the trans but it has a larger U joint than the early models and wont bolt up. I found the early model u joint connection will fit on the late model shaft but its too large on the outer diameter to fit in the late model center bearing dust shield. So i have a small lathe and trimmed it down to 28mm to match the late model bearing. now it fit like a glove.
20160925_164302_zpsdbn7kpod by Z S, on Flickr
This will work out later as i can reswap the yoke to the late model when i install the 8.8 rear end and be all g2g.
This is where i was able to start the truck just by installing the starter and jumping it old gas and all. But then found the clutch wouldn't disengage to get it into my shop and felt like there was no clutch as well. Thats where i found the incorrectly installed clutch slave. Well i put it in gear while off and started it in gear to get it into my shop. That was the end goal at the time as the truck leaks bad with no window, shot seals and, leaking windshield/splice panels.
Mission accomplished.
20160925_175956_zpsqhj65gsz by Z S, on Flickr
Then I tackled the clutch fiasco. and re-stacked the slave and throwout setup correctly. Had a hell of a time getting it bled correctly as the white plastic ring was long gone to disconnect the master. Found you can cut down a paint can top to fit and disconnect the line FYI. I ended up having to bench bleed the master to get all the air out, all the online how to's here and youtube just were not working at all. After all that she runs and moves correctly, I cant say drive as theres a few other issues that need fixed along the way. While removing the trans I found it empty of oil however also the drain plug was covered in fuzz (who drains but leaves the fuzz?)
20160927_132035_zps4vuepued by Z S, on Flickr
20160927_132127_zpsfrutn8bp by Z S, on Flickr
In that fuzz also found what looks like a tooth or shifter dog, either way not a concern as this setup is temp but a proven running driving setup sells better than one that doesnt.
20160927_132624_zpsdo8vaxdz by Z S, on Flickr
And here hows it was running moving and just prior to starting to work on the driving issues and swapping parts.
20161002_192153_zpsn2opavix by Z S, on Flickr
I have already removed the cruise control as i believe it was leaking internally causing a high erratic idle, so once removed she purrs pretty good at 850-900rpm Also in work of removing the A/C as its in the way and doesnt work currently. If anyone is looking for parts from that stuff let me know ill let it go cheap.
Also it currently has 3 90% tread tires 225/70/R14 and one odd ball 185/75/r14 that ill straight trade anyone local for some OEM steelies with enough tread to last 3k miles as ill be changing them later but dont want to just yet. Local being Arkansas or willing to travel to me.
20161008_103252_zps8xjuybcd by Z S, on Flickr
SO ill stop this post here as its the start to a truck i can actually start working on.
So the end goal is to have a JDM lowered 3" front, explorer 8.8 w/ springs swap in the rear giving about 4", restore the interior maybe with a bench seat (if anyone has one let me know), and T56'd turbo'd LM7 5.3(iron block LSX) fun truck.
Feel free to peruse and ask questions!
Z
Z
