Proz07's Black Pearl build
Ik, nice looks just like the original just not dry rotted and painted. Looks like I'll order a set and some panel epoxy get this thing sealed up and windshield replaced.
Thanks
Z
I don't know anyone that sells it new, this is off a second generation from the JY.
You talking the 89-92 or 93-97?
Z
Generically speaking
83-88 - Gen 1
89-92 - Gen 2
93-97 - Gen 3
98-11 - Gen 4
My trim is off a 89-92.
83-88 - Gen 1
89-92 - Gen 2
93-97 - Gen 3
98-11 - Gen 4
Gotcha, that's how i thought but WIKI had it as 83-92 1st gen and 93-11 2nd.
ill keep an eye out at the JY then.
It is kind of fuzzy because it was a constant evolution, the closest thing to a clean slate was in '93 and more so in '98.
Well continued the door rebuilds, I was able to clean the lock and lube it so it works as it should now not all gummed up. Then re-riveted the door passanger door handle as it was loose.
20161016_103636_zps433lvylu by Z S, on Flickr
20161016_103026_zpsnblir290 by Z S, on Flickr
Went to the driver side but realized it was loose because its broke so ill have to order new handles and just do both sides.
Then i started into the window weather seals and after they were in the window groove it actually seals up well. Gonna need to get a new passanger window as the replacement i got was apparently a mud truck and scratched beyond acceptable but it is working to set the seal for now.
20161016_123603_zpsclbshykk by Z S, on Flickr
20161016_123615_zpsvjeilayf by Z S, on Flickr
And since my fan clutch was locked up I removed it and am adding an E-fan. Turns out a Hyundia Santa Fe one speed fan fits almost perfect. I just had to redrill the top holes to relocate the blind nuts and the lower just used some radiator fan zip ties. hope it gives enough airflow, Ill report later.
20161016_181103_zpsnuyafcfa by Z S, on Flickr
20161016_181923_zps4eczj3hp by Z S, on Flickr
Z
Well need to update the wheels, so I got some Lexus is250 wheels pretty cheap 17x8 +45. It'll look pretty good once lowered and installed. Thinking of powider coating them a dark bronze.
20161020_131809_zpsbwhuf1uz by Z S, on Flickr
Now the rear should fit pretty good once my 1.5" hubcentric spacers come in, but the front hub is too big to fit the 60.1mm wheel center. But since the front hub outer lip is 60.4 and the rest of the hub 63.65, I have a small lathe that I can turn the 10" hubs down the 1.7xmm to fit and become the hubcentric spacer. Hoping to get some time to do that tomorrow.
20161021_130652_zps1wd2dwif by Z S, on Flickr
20161021_130658_zpsquw1kgj3 by Z S, on Flickr
Z
Well I dont get much time to work on it during the week but last weekend i finished out by trying to replace the door hold spring as the oem was long ago broke. Didnt realize it was going to take ripping half the truck apart to get to it and realigning the door. But got it done and replaced all the window seals and riveted the window back in. Amazing how new seals make it feel like a new door.
20161023_132630_zpsofpq7qld by Z S, on Flickr
While i was in there i saw how filled with crap the fresh air vent was i vacuumed that out. Think ill clean it up some more later and apply seam sealer to some of the seams in there too.
20161023_135839_zpsdcq7p5tv by Z S, on Flickr
And finished by trying to swap out the power steering gearbox with the manual one i picked up, however thats when i found the manual box has a different pitman arm and is no longer made. I ordered a Vega 1" 36 spline one on accident and it didnt fit obviously. I thought i was ordering the Saginaw 525 pitman arm which should fit as it is supposed to have the same taper, so im waiting on the new pitman arm to come in. And during that i found why the steering wheel have a half a rotation before engagment. The center tie rod that bolts to the pitman arm was completely gone. so ordered all new tie rods to be done with it.
20161024_113942_zpsbhyhtidi by Z S, on Flickr
And this weekend I had a friend come over and help me rip the bed off the truck. Only broke 2 nut plates and had to grind off one bolt head. THose are $15 bolts and $10 nutplates BTW!!! As well as rip out the old 7.5 to make room for my 8.8 after i cut it down. We were going to box the rear frame and c-notch it but i didnt have enough plate to do both sides. So i think what ill do there is get a bolt in set and use the plate i have to box in the inner side and weld it all in rather than bolt it.
20161029_164704_zpstxbxwzln by Z S, on Flickr
THen we moved to the front to rip out the early model I beam setup to get ready for the 96' i beam, knuckle, rotor, caliper setup ill be running. It wasent too bad except the last spring perch bolt on the passanger side would not come out.... ended up needing to use my 20T press to get it out. The bolt was fine just super tight in the I beam. Need to order the spring perch isolators for it as they fell apart and thats where we left it saturday. More to come sunday!
20161029_164725_zpsuangswhw by Z S, on Flickr
Ok so after a little back and forth research and wrong part shipping I have the steering put back together using a universal saginaw 525 arm that I tapered to the ford 7deg end with a speedway motors ream. the original hole I overreamed since i didnt measure when i should have so it got redrilled and reamed correctly farther down the arm. This leaves it right about where the OEM power steering pitman arm is in length. good enough for now till i determine if its fast enough and light enough to extend it later on. Still need to align when my 4deg adjustment cams come in as the 2 deg just isnt enough.
20161112_174535_zpsx6eftnnh by Z S, on Flickr
When doing this I installed my DJM lowering I-beams and all new bushings and spacers for the front suspension and sway bar. I also discovered the single piston caliper brake hoses are NOT the same and needed to get the brake hoses from a 4-wheel ABS late model to fit with my non-abs early model and the 2 piston- calipers. I say 4-wheel ABS because then the front drivers side doesnt have that weird T-block, it fits just like the non t-block I have in the 2wd 88.
20161112_174527_zpsqzpfx6x5 by Z S, on Flickr
20161112_174513_zpscycs8vww by Z S, on Flickr
Replaced the old dry rotted brake reservoir as well. May still pull the master and clean up and repaint the booster later.
20161112_174446_zpsumbe0irb by Z S, on Flickr
Then once the knuckles were on i machined down the hubs and spacers to fit the front wheels. Fits pretty spot on but still need to align when my 4deg cams come in and i may be able to get away without rolling the front fenders, but we shall see.
20161107_125801_zpsw0chwtso by Z S, on Flickr
20161107_125812_zpswpqluyrr by Z S, on Flickr
20161107_125745_zpswoc7cllx by Z S, on Flickr
20161109_120514_zpsonbwbe60 by Z S, on Flickr
20161109_120454_zpsmaqudzy7 by Z S, on Flickr
Thats where i stopped at the time as i was waiting on parts for the front, so i moved on to C notching the rear.
20161113_151438_zpsznu77v9w by Z S, on Flickr
used the plasma to cut out the notch
20161113_172048_zpsmil4e5du by Z S, on Flickr
20161114_101817_zpsqkgdhj3s by Z S, on Flickr
20161114_101801_zpssdexgvw5 by Z S, on Flickr
Due to the frame there is a 1/2" gap at the bottom so i will be boxing it in with 1/4" plate as well as the back side with 3/16".
20161114_101830_zps0t6ar7mw by Z S, on Flickr
I was playing with some settings on the MIG on this first one so its not what id like to see but its more than functional and I will finish the rest of the boxing when my new c25 tank comes in.
20161127_113114_zpsm4j4xx1g by Z S, on Flickr
and back side prepping for weld
20161127_121122_zps6uqdmtch by Z S, on Flickr
Once i got both C-notches in I wanted to start on the axle. so started tearing it down to shorten.
20161127_142609_zpsxfzmems1 by Z S, on Flickr
And after i got all the brackets cut off and fixed minor nicks on the axle tubes i determined i need different gas in my MIG welder to do it right at this point so I stopped after i cut the axle and started the mock up. So i need to wait till i get a new gas bottle or come back this week and finish it with my TIG.
20161127_190945_zpszab9ypjp by Z S, on Flickr
Still need to do final mock up by putting the diff and axle in to verify but its ready to weld up.
Z
Well another weekend comes and goes too quickly, but after getting it realigned and the TIG setup i had just enough gas to tack and then finish welding up all the mounts on the axle housing and the final welds on the boxed frame underneath.
realigned and ready to go...
20161203_124613_zpsk9szyfej by Z S, on Flickr
tacked and aligned....
20161203_125948_zpsazwimkk7 by Z S, on Flickr
almost finished... this super glue is pretty good stuff
20161203_132644_zpsesh9dad1 by Z S, on Flickr
And went back over the mig welds as they had issues.... used the TIG to pull out all the impurities and bubbles.
20161203_134716_zpscudhgxob by Z S, on Flickr
And the spring perches and sway bar mounts are stuck to the housing. Hope adding the sway bar back in helps in the handling dept. the old 7.5 didnt have one.
20161203_201257_zps3kjxzqjd by Z S, on Flickr
Finished boxing frame
20161203_201246_zpsqayubry0 by Z S, on Flickr
And last but not least finally mocked up to get all the hoses and sway bar mounts aligned and final mount tabs installed before paint and rebuild the rear with new bearings and seals.
20161205_104137_zpszue0jswv by Z S, on Flickr
I wanted to have it down and on the ground at the end of this weekend but alas that didnt happen as usual. Im waiting on some steel tube to come in to relocate the upper shock mounts as im using the explorer lowers which locate the shocks at about a 45 deg angle to the axle. After that bar comes in ill weld the old upper mounts to it and weld it into the frame. Then Ill do some final light frame cleanup and rattle can paint. I just need more time in the day to do this stuff during the week.
Z
Ok finished up the last bit of fab this weekend. Here I was mocking up the new shock upper mounts. welded in a 3/16"X1 1/2" Bar across then hacked up the stock shock mounts and welded them in. This seemes good with the lowering shocks I have however they are now short I believe on the extension side once the axle has all the weight in it from diff, axle, brakes, tires.... May have to get longer. Ill wait till i get it back on the ground and the beds on to determine that. I think the explorer springs are a bit heavy right now so i may need to remove a leaf or figure out a different spring to get the drop i want.
20161210_134454_zpspjhy3u79 by Z S, on Flickr
20161210_134439_zpspvpjlrby by Z S, on Flickr
And mounted
20161210_145614_zpswrdvfpsu by Z S, on Flickr
Then it was time to rattle can a little paint.
20161210_164841_zpsoocgiszq by Z S, on Flickr
20161210_164854_zpsnbqkunn1 by Z S, on Flickr
After that it wastime to reassemble the axle and start getting this thing rolling. New bearings, seals, E brake shoes as you can see these were probably original.
20161211_180946_zpsffvv9chp by Z S, on Flickr
And getting the sway bar on and mocking shocks. Sealing up the diff cover.
20161211_191734_zpsyxdzmpgr by Z S, on Flickr
20161211_191748_zpsnx0mjeqr by Z S, on Flickr
And just because i machined my rear spacers to mock the wheels.
20161211_203003_zpshhi7wto0 by Z S, on Flickr
20161211_203014_zps0mtpgaos by Z S, on Flickr
And thats where i called it quits yesterday. Still need to mount all the brake calipers and add a small section of line as the stock is about 6" short now. I was gonna knock it all out but i figured now would be a good time to paint all the calipers as theres no fluid in them currently. So all in all this build is taking way longer than id anticipated due to all the cleaning, painting, re lubeing, and anti siezing every thing since 28 yrs leaves everything pretty bone dry of lube.
Z
I kept my brake lines set up like how a Ranger is.
I got two new passenger side softlines, added mounts to both to my aftermarket perches and put the Ranger splitter block on top the diff as it was on the 7.5.
Looks factory (and for me got the brake line up and out of harms way and removed it from any articulation concerns)
I would post pics but photobucket crashes my firefox both times I have tried it today.
I'm opting to keep the explorer setup and just tack on the line mount to the left rail. Only thing I'll really have to do is add a short run of line.
I'm assuming you did the disk conversion too?
Z
Z
Yeah, 8.8 out of a '96.
Made the 6" extension for the rear brake line and got everything bleed and all the old im sure original sludge out of all the lines.
20161217_150504_zpsh7g8y1ec by Z S, on Flickr
At this point i realized it wasnt going to sit at the height i wanted so i flipped the rear shackle mounts and picked up belltech springs.
20161217_130726_zpsgfec7xs1 by Z S, on Flickr
20161218_173555_zpskxtihqrr by Z S, on Flickr
20161218_173539_zpspc45ckaz by Z S, on Flickr
Then It was time to get the E-brake setup. and the ranger to explorer wasnt going to work out of the box so I ended up modding the ranger cable hookup and gettting a VW baja bug E brake adapter/adjuster.
20161218_173621_zpsf1xhqzne by Z S, on Flickr
And after waaaayyy too much time and 3 different setups I finally got it to a spot that works and allows future wider tire upgrades.
20161224_133237_zps8m6n7krm by Z S, on Flickr
Then it was back to the front suspension to install the Belltech springs but because they are shorter I had to fix the retention tab on the passsenger side so the spring wont fall out on the unlikelyhood of full extension.
20161224_161327_zpsvcjvmxpm by Z S, on Flickr
And then to get the wheels to fit i had to roll the fenders. If i did it again id probably get 225 tires and a slightly smaller spacer. I dont really think square wheel arches are really the greatest to roll. But it worked, I still need to trim and shift the fender liner yet.
20161224_180547_zpsiwuionhq by Z S, on Flickr
20161224_180622_zpsnjsqrxed by Z S, on Flickr
20161224_190824_zpswchyifwz by Z S, on Flickr
20161224_190835_zpspqlwoly8 by Z S, on Flickr
And then it was time to put the gas tank back in but I found 3 pinholes when cleaning it up and painting so needed to fix those. Since the surroundong metal is still good and they are just pin holes I used a self tapper sheet metal screw through JB weld as a sealant. Good for pinholes, if it was any worse id have gotten a fuel cell. But as long as this holds Ill keep it and add fuel pumps and a swirl tank later, could save the cost of a fuel cell.
20161218_125222_zpsk6ujhxoq by Z S, on Flickr
20161218_130005_zpsbcw0s4z3 by Z S, on Flickr
20161218_173519_zpsq49hdg3z by Z S, on Flickr
20161218_173457_zpsunbprzqu by Z S, on Flickr
Hope to get the bed on later today and roll the rear fenders. Get a good side stance shot. Also finish the alignment, I got the camber to about -1 deg but still need to get toe and steering aligned.
Hoping to get that and then remove windshield to get the cab re seam sealed and schedule new window install this week. should be able to start driving it after that! Then all smaller tasks, interior, dash, getting the rest of the parts for the LM7 swap etc. Maybe get the roll pan on early spring. I dont plan to do the engine swap till late summer/fall time frame.
Z
