Project: Moose-Knuckle
Featured Build Threads
LittleBigFoot
Denver Colorado
TOTM INFO:
2000 Ford Ranger XLT, 3.0l flex (DEAD) 4r44e auto with electric BW1354
Front:
Full Width HP Dana 44
Molly shafts
4.30:1 gearing
Open diff
52" Chevy leaves with 8" shackles
3/4 ton ford van power steering box
1 ton TRE's
Home built high angle drive shaft (tom woods can eat my shaft)
Home brew shock hoops
Warn lock outs
Rear:
31 spline 9"
Molly shafts
4.30:1 gearing
Open diff
63" chevy 1/2 ton leaves
Belltech shackles
2" block
5/8 u-bolts
Cantilever shock system
Home made drive shaft with 1350 yokes
Tone Ring is a BMX bike gear tacked to the pinion yoke with a bracket for the vss.
General:
Around 8ish inches of lift
35x15r15 super swamper LTBs on gnarly offset stock 79 Bronco Rims
82" track width (out side of tire to outside of tire)
112" wheel base
Measured at 22" of wheel travel front and rear
Tube stinger bumper made of .120" wall, 1.75" O.D. HREW with front receiver hitch
Home brew rock sliders made of .120 wall 2" O.D. HREW
33 gallon fuel tank from a 84 bronco massaged between the frame rails
Custom home brew "flat bed" made of 1.75" O.D. .120" wall square stock and diamond plate
A few spare tire carriers
Cobra CB with 48" antenna
Amo box center concile
Rubber undercoated floor with drain plugs
Fried the rings in my 3.0. Pulling the 3.0 currently, and am building a supercharged 408 or 427w w/ a C6 trans. Still dealing with transfercase options. Trying to rig up passenger drop to run a Chevy Dana60 (cost)
Looking at a np203 range box bolted up to a pass drop NP205.
IT'S NEVER OVER.
Still some work to do.
just wondering what your plan is for the RABS sensor. you might think of mounting a tone ring on the driveshaft. a good place for info about it is dezertranger.com
ABS are for pussies. And people in shape.
I think the RABS tone ring is also the speed sensor (for the speedo and computer) on the later model rigs...
http://members.aol.com/jzettel73/Military_Axle_Swap_5.html
Tone Ring Change Calculations
Tire Circumference: 35" x 3.1416 = 109.956"
Revolutions per Mile = 63,360 / 109.956" = 576.2304
(63,360 is the amount of inches per mile)
Conversion Constant = 576.2304 x 108 / 8,000 = 7.7791104
(108 is the number of teath on the tone ring. 8,000 is a the number of pulses per mile the PSOM needs to be accurate)
Teeth on New Sensor Gear =
(8,000 x Conversion Constant) / (Tire Rev. per Mile x Ring & Pinion Ratio)
(8,000 x 7.791104) / (576.2304 x 5.13) = 21.085
Now the question is, should I use the stock ratio for ring and pinion, (4.10:1) or the not installed but desired gear ratio?
I will have a gear made with 21 teeth at a machine shop. I'll do it up like this dude did:
Adam
And I've heard different things from tons of different people about not using the VSS with automatic trannys and not having shifting issues or ABS issues.
I'll pull the vss tomorrow and give her a cruise and see if it even works. I know the ABS light will stay on. But hapiness is just a bulb pull away
Best one I've seen done.
IZwack said:
This is what I did when I switched to the GM 14-bolt axle:
Tone ring cut from an old Dana 44 carrier bearing and then welded to the transfer case's output flange:
Ford 8.8 sensor mounted on the transfer case:
This is the sensor up against the tone ring:
Calculation for the number of "teeth" count required at the transfer case mounted tone ring:
New Teeth Count = [Old tone ring teeth count] / [Gear Ratio of differential]
The old tone ring of course is the one pressed onto your old Ford 8.8's carrier.
how does he plan on ahving the bolts go all the way through that flange with the tone ring overlapping
moose knuckle...because camel toe has an ugly cousin;missingteeth;
:headbang:Should be one sick ranger when you are done.:headbang:
That setup is on an explorer and has been used and abused. He has the correct length bolts, that engage the thread but dont stick out the backside.
if you pull the vss your instament cluster will light up like a christmas tree and you will be stuck in first gear, i know mine went out on my 2000 ranger had to drive it 10 miles homes in 1st
sweet it looks like you have the right idea. I was going to do a 9'' but it was becoming a pain in the ass to find someone to build me a tone ring. good luck and cant wait for the build.
Mitch and I began tearing down the Heap today. All doors, body pannels, fenders, and rear alxe and suspension are gone. I have some buyers lined up for parts to help with the Ranger costs.
I pulled the VSS out of the diff and went for a cruise. It shifted normal, and I had my speedo.
BUT: I have been rocking front wheel drive for a while. I've got no rear drive shaft in, and I just hang out in 4wd. I didn't have time to look. Is there another VSS in the front?
From what I've heard, Jeeps use tone rings in the output shaft of the transfer case. I'm going to rip apart the Jeeps blown t-case and check the gear. It's crazy enough it just might work!
Here's the state of my garage and Jeep
Featured Ranger Based Vehicle
